Question about Samsung Dryers
My electric dryer is not heating , what is wrong?
  • 1,998 Answers
In all electric dryers there are mainly three components that make up how the dryer heats the heater, the hi limit thermistat, and the low limit thermistat. These are the three main pieces i find cause a unit not to heat you can perform continuity tests on all three to assure which part is at fault if you had all three in proper fucntioning order after you did you test then you would look at the timer as haveing a fault but conduct your tests this is usually where the problem lies also make sure your setting is not set to air dry and that you have 110 coming in from both sides of the plug if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks I await any further questions you may have
Rick
Posted on Apr 03, 2011
I changed the elimint and still no heat what els could be wrong
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 09, 2011 | Kenmore 62602 Electric Dryer
General Electric DVL223EB1WW Electric dryer no longer heats up. Still blows air, cold, but no heat?? Any suggestion?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 15, 2011 | GE DVL223EBWW Electric Dryer
Kenmore dryer not heating up
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
I have a Crosly Dryer. It no longer heats. What is wrong and where would I get the part?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | Crosley CDE6000 Electric Dryer
Electric GE harmony dryer runs but will not dry. Do these newer models not have heating elements? if not what has gone wrong with it?
heatman101
Oct 19, 2010 | GE Profile Harmony DPGT750EC Electric...
How do you know if dryer thermostate is bad on estate electric dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out the electric dryer no heat tip...
heatman101
Sep 06, 2010 | Estate TEDX640JQ Electric Dryer
Dryer estate whirlpool not heating after changing thermal fuse what could b wrong
heatman101
vxczvxc
Aug 31, 2010 | Estate TEDX640JQ Electric Dryer
My dryer no longer heats. What's wrong?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | Dryers
LER4634J Electric Dryer: dryer will not heat...
heatman101
[p]
May 17, 2010 | Whirlpool LER4634J Electric Dryer
Dryers Logo
53 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
