Question about Samtron 96BDF 19" CRT Monitor
I have a Samtron 98bdf that has had this blurry screen for a while now. I thought I should take the back cover off just to see if there's anything obvious that could be wrong (or adjusted). Problem is I can't seem to get the cover off. I loosened the 2 bottom screws but this doesn't help with loosening the top portion of the cover. Anyone know how to loosen the top part of the cover? I would appreciate the help!
2 Suggested Answers
  • 68 Answers
SOURCE: samtron 98BDF
Since your monitor is recieving data I would look at your computer hardware for the solution. Did you recently add a program to your computer? Or change a BIOS setting ? Did you have problems with your hard drive?
Posted on Sep 20, 2007
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
I have a Samtron 98BDF crt monitor that has a focusing problem. I notice the more I turn down the contrast, the image will eventually get sharper. If I turn the contrast up the image will eventually get...
I have a Samsung Samtron 97BDF and i have problems with the information cable, so i need to change it, how can i do? Maybe someone have pictures about how to make..
Sep 14, 2010 | SAMTRON 98BDF 19 in.CRT Conventional...
I am trying to clone my lapptop image with a samtron 73.v and the samtron seems dead :-( It says Test Good but does not work
Most laptops have three video-settings:
* output only to internal screen
* output only to external monitor
* output to both internal and external
Select the appropriate video-setting.
Set your laptop's screen-resolution to 800-by-600 by 60Hz -- a resolution that should be compatible with any 15" Samtron monitor.
Dec 26, 2009 | SAMTRON 55V 15" CRT Monitor
Blurry tv screen
If you are comfortable on doing adjustment with working TV then take off back cover of TV and check flyback transformer, there you would see 2 control knobs, upper knob if to adjust focus. rotate it CW or CCW to obtain maximum focus on TV screen.
Put back cover and enjoy.
Feb 10, 2009 | GE Televison & Video
Picture is blurry
this is a problem wit your stk392-110 convergence IC's - One has gone bad and the both should be replaced. Also, check the large resistors near the convergence IC's - it sounds like one of them may have burned up..
Feb 02, 2009 | JVC AV-56WP30 56" Rear Projection...
Removing back cover of samsung monitor 15'' crt 55v
I need some solutions to remove back cover for the CRT samsung monitor
Jan 17, 2009 | SAMTRON 55V 15" CRT Monitor
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 98BDF
Sep 18, 2007 | Samtron 96BDF 19" CRT Monitor
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Computers & Internet Logo
55 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
