Question about Dryers
Global Industrial FB2-65X (3) 607050 24" wall fan
  • 1122 Answers
SOURCE: WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Posted on Oct 02, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
carldc3
  • 82 Answers
SOURCE: I am converting a 3
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Posted on Jan 05, 2009
Greg20
  • 149 Answers
SOURCE: What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Posted on Jun 22, 2009
  • 351 Answers
SOURCE: trying to convert my dryer from 3 prong to 4 is
Hi .. I am posting a sketch of the 3 wire and 4 wire connections .. if you have any questions please get back to me ..
Posted on Jun 19, 2010
Which brand of industrial seals do you use?
I use tydenbrooks for my company. My staff suggested me about it. It doesn't have much of bad points but sure do have plenty of good points. I love how it has wide range of industrial seals to choose from whether you like padlock or wire seals or electronic seals or plastic seals and many more. It can overcome high strength and has warranty as well.You can try this site Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Mar 27, 2014 | Global Industrial 00 5x10 Self Seal Kraft...
Where from can I buy some high quality industrial seals in affordable price?
It's quite obvious to face problems when we have plenty of options in front us, then we start asking different people regarding this, though we can get one conclusion for which we are seeking. Actually, it is good to ask or consult with different people so that we can get an appropriate information or an extra information. Along with asking different people you can search on google which is fruitful for you apart from this you can compare different companies quotes of wires and cables, what kind of quality product they were providing, price details and many more things.
Mar 05, 2014 | Global Industrial 00 5x10 Self Seal Kraft...
"Ball Ceiling Fan" - hardwired wall switch only turns on or off, no speed control or light control, stuck on "high" and light "on" when switch is in "on" position.
The most likely cause (and the one I've always encountered) is the switch/controller nit wears out from electrical arcing that burns the contacts or temperature kills electronics on "soft" speed controllers
Mar 03, 2013 | Modern Fan company ball ceiling fan
1. Initially had power to Interior Blower Unit 2. Blower Fan quit running and then lost power to unit. 3. Troubleshoot'n done: a. Wall power supply is good b. Conductivity check on plug =...
Assuming that this is a personal AC as opposed to industrial blower unit, see if you can manually spin the blower with the unit supposedly ON and running. Wear eye protection. It's possible that the motor burned out; there are LOTS of tiny wires in the motor coils.
Jul 16, 2011 | Heating & Cooling
My heritage 56 inch industrial fan gets very hot after a short time running i am very sure that it was wired correctly. just dosent make sense that the motor gets that hot.
mcdevito75 here, The fan motor should get very, very warm to a bit on the hot side, in other words not so hot as you can":t keep a hand on the fan motor. Also if you have other items on the same circuit as the fan, lamp, A/C unit this added load can cause fan to get hot, also wear and age on the fan contribute to heat. -------Check wall switch, feel if that is also getting hot or very warm along with the fan, if so you may need a new fan.
Jul 25, 2010 | Heritage 56" Industrial Ceiling Fan
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
78127 remote switch
With a switch it is always the hot wire (black or red one) that goes through it. If it doesn't work, it may be a faulty switch. They make everything in China now, after all.
Jan 19, 2008 | Westinghouse 78127 Industrial Ceiling Fan
Dryers Logo
409 people viewed this question
Top Dryers Experts
