Question about SAMTRON 98BDF 19 in.CRT Conventional Monitor
My Samtron 98bdf has a blurry screen issue. I thought I should take the back cover off just to see if there's anything obvious. Unfortunately I can't get the entire cover loose. I unscrewed the 2 screws at the bottom but it only loosens the bottom not the top. Anyone know how to loosen/release the top part of the cover? I would appreciate the help.
  • Matt
    Matt Apr 05, 2011
    DUH. I would have replaced it if I had the money.
  • Matt
    Matt Apr 05, 2011
    DUH. I would have replaced it a long time ago if I had the money.
jackboy
  • 2985 Answers
SOURCE: Remove cover
Its a snap together job But unless you know where to start something will snap. Try the Samsung Tech support for this product. Even if the Back light or inverter or some other do able thing is doable- getting parts may not be so easy for you. So follow their advice for service.
Posted on May 15, 2007
  • 68 Answers
SOURCE: samtron 98BDF
Since your monitor is recieving data I would look at your computer hardware for the solution. Did you recently add a program to your computer? Or change a BIOS setting ? Did you have problems with your hard drive?
Posted on Sep 20, 2007
SOURCE: Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Posted on Nov 13, 2007
SOURCE: problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
Posted on May 15, 2010
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
Sony Bravia Model No. KLV-46Z450A screen problem. 1/3 of screen is fuzzy/blurry.
remove the back cover then tried first to fix connectors wire which may have loose connection. then if still the same issue, check the D board if their is a burnt parts.
Mar 26, 2013 | Televison & Video
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
I have a Canon PowerShot 850IS that is about 3 years old. It has been a great camera...up to this point. Just recently I went to take some photos and the bottom half of the images are blurry. Seems odd...
Could be that the lens cover doesn't open fully or that perhaps there is a smudge on the bottom part of the lens. Maybe a water drop. IF the front optics are dirty, use an optical-quality lens cleaning solution and cloth (if you have glasses, the lens cloth that came with your glasses). Apply a very small amount of cleaner to the cloth and gently clean the lens.
If the lens cover doesn't open, could be a grain of sand. The only thing to do is to gently move the lens cover in and out & hope the sand works its way out.
Mar 02, 2011 | Canon PowerShot SD870 IS Digital Camera
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
I am having issues with my Polaroid FXM-2611C Flat Screen TV. It turns on and shows the Polaroid image in the middle of screen but also shows a duplicate image at the bottom of the screen. When the...
If you have a soldering iron and a capacitor tester you can check each cap out one by one, making sure that when you put back in a good one you observe the original polarity. If a cap has blown or is leaking it is obviously bad.
Boards can be expensive and perhaps not cost effective for a repair when you can get a new set for about the same money with a warranty to boot!
Apr 09, 2017 | Polaroid FXM-2611C 26 in. LCD Television
I have a Samtron 98BDF crt monitor that has a focusing problem. I notice the more I turn down the contrast, the image will eventually get sharper. If I turn the contrast up the image will eventually get...
I have a Samsung Samtron 97BDF and i have problems with the information cable, so i need to change it, how can i do? Maybe someone have pictures about how to make..
Sep 14, 2010 | SAMTRON 98BDF 19 in.CRT Conventional...
I have a Samsung CRT monitor, every time when I switch it on it constantly changes the colors for atleast 20 min... after that it just works fine. is there any options to service or changing the monitor...
Sounds like the monitor have a "cold joint" or having issues with overheating parts. I believe your monitor was used for long periods of time with no power saving active.
If you are a technician and are planning to fix it, you need to solder all cold joints. Also maybe the filaments inside the CRT are reaching the end of it's life.
Instructions how to open the samsung display: http://josepino.com/?open-samsung-back-cover
Dec 22, 2008 | SAMTRON 55V 15" CRT Monitor
My screen broke
No unfortunately the warranty does not cover cracked screens. But you can purchase a new screen. Click here.
Oct 01, 2008 | Creative Labs Zen Digital Media Player
Samtron 98BDF
Sep 18, 2007 | Samtron 96BDF 19" CRT Monitor
SAMTRON 98BDF 19 in.CRT Conventional Monitor Logo
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
