Question about Jensen Car Audio & Video
I bought a jenson uv10 stereo dvd player i have hooked up all the wires and there is still no power...i see there is a green white wire that says reverse postive what is this for and where do you hook it up at
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Posted on Feb 20, 2009
etirbynnor
  • 655 Answers
SOURCE: what wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Posted on Apr 14, 2009
  • 37 Answers
SOURCE: bought a new whirlpool ceran cooktop it only has 3
There should be a diagram in the installation instructions packed with the unit showing how to connect them.
Posted on Sep 01, 2009
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Mar 20, 2011 | Mitsubishi Raider 2006-2007 Car Radio...
Im trying to hook my stereo in a ord focus 2005 but to many wires any solution please to get conected
Check this wiring for 2005 Ford Focus Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Hope help with this; keep us updated.
Feb 07, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
I bought a xdvd700 off of Craigslist and it did not have the power harness so I bought one and when i tried to wire it it won't turn on. How can I tell if it works or if I am just wiring it wrong there are...
The only wires that must be connected to power up are Red(Ignition) Yellow (memory) and Black (Ground) The red and yellow can be ran directly off of the battery for testing purposes. It's not uncommon to have an extra wire or two when wiring a stereo.
Good Luck - Hope you got a stereo that works.
Jan 31, 2011 | Dual XDVD8170 Car DVD Player
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
I need a diagram of stereo wiring to hook up a cd player
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Jun 11, 2009 | 1987 Mercury Cougar
I need to hook up cd player
something i found today on google. hope it helps.
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
May 09, 2009 | Sony CDX-CA400 CD Player
Need to know how to hook up a sony cd player
see if this helps bro.
May 09, 2009 | Sony ATRAC MPS/CD/AM/FM Personal CD Player
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
Car Audio & Video Logo
100 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
