I am having problems connecting - Computers & Internet
  • 109 Answers
Some of the antivirus program block the softwares which are required for the functioning of the modem so you have to make the preograms into truster list other problems are related with the network
Posted on Apr 03, 2011
D-Link DIR 600 connection problems
If this is the case, there is no problem with the router. the problem is with the modem.MAke sure that the cable from the modem goes into the WAN(Internet) port of the router.And also, what kind of internet are you using? is your router set up properly to work with your provider?
Is there any problems when you connect your pc to the modem directly with the cable, or does the problem occur only in the wifi connection?
Feb 18, 2012 | D-Link DIR-600 Router
Internet connection/network adapter problem
If you are using the Windows own Wireless connection wizard (Wireless Zero Configuration service aka WZCSVC) this is designed to recheck every 20-30 mins for another connection this is your problem disable the service here download this tweak.
http://rapidshare.com/files/260751524/Disable.WZCSVC.reg
Then download and use the laptop NIC's own software to search for your Uni server and then connect using the WEP or PSK, this will solve your problem then create a profile in the NIC connection software and it will never forget.
LOL
Sep 27, 2009 | Acer Aspire 6930-6455 Notebook
Network Connect Problem
If your machine is initially connecting then not connecting after some time. I would try the following:
1. Ensure you have a stable connection with your Internet service provider. Check cables and make sure you're not having any power or connection issues with your modem.
2. If this does not seem to be the source of the problem. You may have a problem with malicious software as the connection seems to work initially and then stop. Go to Download.com and download Malwarebyte's Antimalware and scan your machine.
3. If this doesn't solve your problems you may be having hardware issues which may require a replacement of your network card or connected device.
Apr 08, 2009 | Dell Optiplex 755 Minitower Desktop...
Internet connection failed
Try so see first the network connections in your PC. Go to your control panel of your PC select network connections then click the appropriate settings you want(just read the instructions then click). Having done this, and you have seen that there is no problem in your network connection settings then probably the problem occurs on the hardware connections. If you are using Cable modem, make sure the connections are fitted in, also with other type of internet connections except wireless connections. If having done this you still has the problem, it is now on the service provider has the problem, sometimes wired internet connections lost connections for a few minutes or more. Sometimes a blackout in the area of the service provider, so there is no power source that can be used to supply the network.
Mar 05, 2009 | RTO Eset NOD 32 Antivirus System 3.0 Full...
Problem connecting nokia 3220 with pc
Sir I have nokia 3220 i have problem problem connecting it with pc. I have also installed nokia pc suit but it it shows that no phone is connected.Should i install drivers or somthing else please help me on this
Feb 18, 2009 | Nokia 3220
Zoom
You may do isolation to sort out Internet connection problem. If you are experiencing Internet connectivity problem and you are using a router, then bypass the router and connect your computer directly to the modem. Observe then if you will experience or not the same problem that you have when PC is connected to the router.
For wireless connection problem and you only have one wireless computer, then try connecting your wireless computer to a different wireless network and check if same problem is experienced.
In these ways, you would know what device to re-configure or re-set up.
Hope this helps!
Nov 11, 2008 | Zoom 4420 (44200000) 802.11g/b Wireless...
I am having problems with my wireless connection. When I try to connect to a wireless connection such as an airport, coffee shop, etc. I get a connection to the network but am unable to connect to the...
tht is becasue u odnt have heir WEP or WAP password if it has a password then ur adapter will seem to connect to it but wont give u internet access to the router which means no intenet
Sep 25, 2008 | Computers & Internet
Problem with net connection
please, i want to know how to solve this problem that my laptop is demanding for the updated driver for realtek adapter before i can be connected through wireless mode
Aug 30, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Problem in internet connection
check fire wall setting if u have a back up for ur security soft remove it from the computer and try disabling all startup items
then check
May 19, 2008 | Compaq Presario M2000 Notebook
DI-524 connection problem
hi.
you need to configure the wireless encryption key on your desktop computer.logon to your router and configure wireless setting and configure your desktop with the same SSID / wep key and it shud connect.post back any errors
Feb 13, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
