Question about HP VP6310 Multimedia Projector
Unresponsive projecter I was updating the projector firmware when my laptop froze. Despite warnings not to disconnect the projector while updating, I did so anyway. Now the projector, when turned on, shows red on both the lamp and temperature lights, and is otherwise totally unresponsive. Prior to this, the lamp was in fine condition, and the temperature light can't be right, as it comes on even after the projector has been left off overnight. How can I "re-boot", as it were, this projector? Please help!
    Problem Solver:
  • 18 Answers
You need to replace the logic board.
Posted on Jun 06, 2009
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
Firmware update
We regret to inform you all firmware updates must be performed by authorized service centers.
Apr 08, 2014 | Panasonic PT-VX400 Projector PT-VX400
Firmware update pt-vx400
I don't believe that there is a 'User' update firmware file available, the only thing I could find was this site which gives you all you can download. That is unless you have members access to "Panasonic Projector Extranet" which is for resellers (i think). Best to contact Panasonic directly or a Panasonic Main Dealer who may be able to eith send you the firmware via email or update your device for a small fee?
PT VW330 VX400 VX400NT
Apr 08, 2014 | Panasonic Office Equipment & Supplies
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
Plc-xu105 will not restart. red on, no fans
SAYA MEMPUNYAI SANYO PLC XU105 , JIKA DIHIDUPKAN POWER LAMP MENYALA HIJAU BEBERAPA DETIK KEMUDIAN LAMPU WARNING LAMP MENYALA, KIRA KIRA KERUSAKANNYA DIMANA YA..? TOLONG YA SOLUSINYA..THKX
Feb 19, 2010 | Sanyo PLC-XU105 Projector
Mitsu x400bu gives coprright indication when i go from hdmi todvi
Firmware update, yes or use component video. HDMI has embedded copy protect and is really an aggravating connection. Consider this, hdmi's benefit is embedded audio, your projector does not need this. Component video will meet you needs because the projector is not real high on res. Good luck
Mar 24, 2009 | NEC Mitsubishi LVP X400BU Multimedia...
Trying to update Firmware on a Sim2 HT300
Take it to an Authorised SIM2 service agent . Some things are just not for the DIY
Dec 19, 2008 | SIM2 HT300 Multimedia Projector
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
http://www.infocus.com/Support/Products/Projectors/IN24.aspx
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
HP VP6310 Multimedia Projector Logo
121 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
