Question about Linksys Wireless-G WRT54G Router
I changed my ISP and I have Comcast now...I connected the Internet oulet to my new modem, then the router, and then, my desktop....but it is not working
  • Martin Banner Apr 03, 2011
    What internet provider where you using before? When you plugged everything in was it all turned on?
  • osvaldo_h Apr 03, 2011
    AT&T...now, Comcast
    Master:
  • 451 Answers
Did you use to have DSL? it could be that it was set to PPPoE.
login to your router and set the WAN connection to obtain a IP address auto.
and disable PPPoe.
do this by going to internet explorer
browse to http://192.168.1.1
login with your login/pass otherwise the default login is blank and the password is admin
Posted on Apr 03, 2011
How do I get my Zonet Router to play nice with my Motorola Modem and Comcast Connection?
If this types of issues again again then may be some technical Fault.
A> Your Network connectivity Not Good or loose.
B> Your IP Add or mac Add change or conflict.
C> Your Modem or router not proper connectivity establish.
D> Contact network ISP provider or ask some issues.
E> If possible check it loose connectivity and connection.
If not solved contact Network Support Technician.
http://setuprouter.com/router/zonet/zsr4154we/manual-915.pdf
Linksys Support Phone Number
Thanks,
Sep 05, 2014 | Zonet ZSR4134WE Wireless Router
How do i connect a netgear wireless router to comcast modem
Unplug your Comcast modem from your electrical outlet. Connect the Ethernet cord from the back of your Comcast modem into the Ethernet port labeled "Internet" on your new router. Connect an available Ethernet port from the back of the new router to the Ethernet port on the back of your computer.
Plug your cable modem into an electrical outlet. Plug your new router in an electrical outlet.
Reboot your computer. Click on "Start," then "Control panel." Click "Network and sharing." Select "Set up a new home network."
Click on the option for a router or cable modem when prompted by Windows to select your hardware. Your computer will attempt to access your new router. When the brand name for your router is listed, double-click it so your computer can configure itself to the new router.
Create a new name for your home network and create a unique password to prevent unauthorized users on your network. Your computer may reset your Comcast modem and router so your new changes can take effect.
Nov 04, 2010 | Computers & Internet
I have a Netgear WNR2000 that I want to connect to a comcast modem. My pc picks up an ip from the router but the router does not get an ip from comcast. I have tried a manual setup using the settings...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 28, 2010 | Computers & Internet
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
Can't connect to the internet through the router. It worked fine until my ISP came out and changed the modem. I can connect with modem connected to Mac but not with modem connected to router.
If this is a cable modem, you need to restart the modem every time you change whatever is connected to it. Every device has a MAC address. Cable modems lock onto a MAC address that is connected to it and will only communicate with that device until you reset it by restarting. Some Comcast modems have a battery pack that must be removed in addition to unplugging it from the wall.
If it's DSL them maybe there is a username/password entered in the management console of the router.
Jun 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
Comcast unhooked it and i dont know how to hook it back up
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
May 10, 2010 | Belkin (F5D7230-4) Router (587009)
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
ISP.
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Followed all directions to connect modem, router and computer but still cannot get an internet connection. what could be the problem
It made not be design for your ISP Internet. To make this clearer, Verizon uses Westell modem for there internet, and Comcast uses motorolas.
Aug 11, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys Wireless-G WRT54G Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
