Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto Rondo RS SBS
After descaling my machine on friday and rinsing with a container fresh water running through the machine. I switched it off. Later that day when I wanted to make coffee there was no water running through the system. I spoke to Saeco customer service 3 times and followed their instructions without success. So now they told me to send it for repair to N.J. Maybe you can help. I sincerely hope so. Thank you very much for a reply.
Regards Lia Perne.
  • 1 more comment
  • wynni Aug 05, 2008
    No no water
    I have just signed in and paid 14.95 for a chat session. I think something went wrong
    I signed in for premium assistance. What happened?
  • 515 Answers
if you open the steam knob, will there comes some water?
Posted on Aug 05, 2008
  • Mirko Blas
    Mirko Blas Aug 07, 2008
    I was not online that day:-(
    If the pump is running and you don´t get any water then i think you have air in your system. Try to find a bellows pump or similar then you have to force in water in the water inlet. Make sure that the pump is running when you do this.
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco Italia that that has led 30(on far right) on steady. It is not initalizing with the zip zip sound but does run the motor for about 15 seconds and the turns on led 30. I replaced the...
Hi
If #30 looks like some lines with little chunks in it, you might be in the descale mode. Remove the water tank and turn on the machine. If the pump comes on when you open the knob on the right, let it run for about 10 minutes. It should stop and after a minute, then run again. If it is doing this, let it go until the lights flash on the front. Then put the tank back on and close the knob, then open it again. When the pump starts flowing water, lift the water tank off, but let the pump run until it quits on its own. This should clear the light, then put the water tank back on and prime the machine.
If that is not what the light was I need to know what the symbol is next to the l.e.d. to tell you what to do.
Nov 09, 2009 | Saeco Incanto Rondo RS SBS Espresso...
Wasted espresso
Check the chamber under the valve, make sure that it is not filled with coffee grounds and water, also there is a small discharge chute under the chamber to the drain tray make sure that is clear.
Sep 12, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
We have an Saeco Incanto Rondo sClass. When brew coffee, only about half of the water goes through the brew group and the rest goes into the drip tray. When we try to run steam or water through the wand,...
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
SAECO SAECO INCANTO DE LUXE
descaling it with special produit not vinegar 1 part descaler 1 part water put in water container start machine open water valve for few second leave it for 15 minute repeat untill empty rinse very good cheers
Jan 21, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
147 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
