I need to know how the source and input and contacts work in relation to each other as well as a wiring sch for dayton 1egb3 time delay relay
  • 1 more comment
  • milligan62 Apr 04, 2011
    What and how does a delay off work and do you have a schematic for it?
    Sorry I was just hoping I was wrong but no such luck...Found a relay but it has the wrong fuction for my app. Thanx for your help!
    Yes. VERY!
  • 8,220 Answers
Their are 2 types of these. Delay on make and delay on break. Most folks In my neck of the woods prefer the delay on break model. Here is how it works. The delay on break is wired into the low voltage
24 volts wiring. When the power goes out for a split second the delay on break does not let the unit run for a pre-determined rate. Most of em have a dial to set from one minute to 5 minutes. This relay prevents children from monkeying with the thermostat and burning the contactor up. It also protects from power surges.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 03, 2011
  • Dan Webster
    Dan Webster Apr 04, 2011
    I have a delay off relay on my unit. The outside unit shuts down and the inside stays going for 30 to 45 seconds to allow all the cooling possible.
  • Dan Webster
    The unit gets the command to shut down and does so after a pre determined or pre set time on these little relays. What ya want patent info? Sheesh.
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
How do you connect up to the dayton ssr 1EGH8?
Wiring diagram is not found on internet for that device
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+1EGH8&op=search&Ntt=dayton+1EGH8&N=0&sst=subset
Contact WW Grainger for information.
Grainger owns Dayton.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service cal
Mar 26, 2011 | Amperite Dayton Solid State Timer On Delay...
Off delay for Lighting
You will need a timer. Run power line from input of door opener to timer. Set timer for 5 minutes connect lights to timmer.
Jul 21, 2009 | Amperite Dayton Solid State Timer On Delay...
Wiring a dayton timer relay
Open following link for illustrations showing how to wire 8 and 11 pin off-delay timers:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 01, 2009 | Amperite Dayton Solid State Timer On Delay...
How to wire a dayton off delay timer relay for 1 min. solenoid ac
found a reference to the relay class I was in need of information on here:http://www.hauntedattraction.com/38/currentissue_workshops.shtml describing a particular circuit r&d that I could equate to my dilemma... took a little mapping out of the schematic as I read, but wasn't too difficult to correlate. It pays to persevere in your googling methods ;-)
Apr 17, 2009 | Amperite Dayton Solid State Timer On Delay...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
