Question about Atlas Model Railroad Atlas 10000706, Ho Scale, Alco C425 Haven 2551
MOTOR STOP WORKING.NEED REPLACEMENT.CAN'T FIND ONE.!!!
  • 2 more comments
  • vcand Apr 03, 2011
    I do thak you,honestly.
  • vcand Apr 04, 2011
    EMD SD60 PROTO2000 DETAIL KIT IN METAL?
    STILL LOOKING.
  • ROBERT SOLANO Sep 09, 2012
    OKAY , HERE IS A WEBSITE THAT SHOULD HELP YOU ; www.atlasrr.com GO TO THE SITE AND ON THE LEFT SIDE IS THEIR BREAK DOWN SECTION , CLICK ON "PARTS" YOU CAN ALSO GO TO GOOGLE , ASK.COM , OR BING.COM AND ASK FOR THE CUSTOMER SUPPORT NUMBER TO ATLAS RAILROAD CO. HOPEFULLY THEY SHOULD HAVE THE PARTS THAT YOU MAY NEED OR BE ABLE TO HONOR YOUR WRRANTY IF YOU STILL HAVE IT .HOPE IT HELPS YOU . ROB - OVER.
  • 8,197 Answers
If you still need help with your problem please raply to this post. If you do not need anymore help please do not reply to the post
Posted on Apr 04, 2011
  • 592 Answers
Hi.
I, too am a model train enthusiast, and I only get my supplies from one place.
A company called " model train stuff".
Here is a link to the part of their website that has the train motors, they only carry high quality parts, so that is why they only have 2 different motors listed.
http://www.modeltrainstuff.com/HO-Scale-Electronics-Motors-s/1967.htm
Neither one costs more than 17.29, so the cost is really good.
About 15-20 percent below normal retail costs, but that is because they are for the hobbyist customer.
I believe that one of those motors is an exact replacement, the E-R model motor.
The Kato brand is more of a generic replacement for all HO scale engines, but select whichever one you want to get.
I hope that you get your train going again, and good luck to you !!
Posted on Apr 03, 2011
95 CHRYSLER CIRRUS A/C BLOER NOT WORKING
A poss bad blower motor or blower motor resistor can cause this. Replace the blower motor resistor first.
May 31, 2012 | Cars & Trucks
2000 honda accord ac fan motor stops working for a few hours, then starts working again. When it stops working, it does not work on any fan speed.
replace the blower motor. try taking off the cover to the blower motor kicking the switch to on and spin it manually. if it gets going on its own then the motor is in need of replacement
Sep 15, 2011 | Honda Accord Cars & Trucks
My 1996 mercury grand marquis wipers stopped working but the turn signal and washer sprayer button works what should i fix or replace?
check fuses if not that look for a short in the wiring near the wiper motor if you dont find one you probably need a new wiper motor,
Dec 04, 2010 | 1996 Mercury Grand Marquis
Fan stopped working
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Jul 08, 2010 | Weather King 10AJA4201AH Air Conditioner
Agitator is not turning
1. You could have 2 issues here
a. the timer is not sending a signal to the washer motor to activate the wash cycle
b. the motor has stopped working and needs replacement
Some washers have a direct drive motor and the bearing usually wear the the circuit sensor stop the motor to eliminate any damage to the washer
The other motor if older is belt driven and the belt may have broken and will need replacement. Some motors just freeze up and lock due to age and need replacement.
I hope this helps. Have a good day!
Mar 16, 2010 | Washing Machines
The blower has stopped working! Tried the fuse but
check for voltage at the blower motor with switch on. if you see voltage there, but the motor isn't working - it needs replaced. if no voltage at blower motor, work your way back to the switch to see if it's working correctly.
Feb 05, 2010 | 1996 Volkswagen Golf
The microwave stopped heating. Everything else is working fine.
Ok, concerning the heating issue. you will need to replace the Magnetron to restore the heating feature in this unit. this device is damaged.
Concerning the motor(circulation). If the motor is not working, this will damaged the Magnetron, due to poor circulation. i recommend replacing the motor asap.
In conclusion, you will need to replace the Magnetron and the circulation motor as well. replacing these two vital devices will fix your issues. the total cost for these parts are estimated at $87.90
Jun 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Ultrex microwave turntable won't turn
turn table motor may be going bad.. it is almost impossible to diagnose untill it stops working completely.. when it stops working completely you can test for 120v down at the motor if you get 120v you need to replace the motor.
Jan 20, 2009 | Microwave Ovens
My heater blower stopped working on my 2002 Malibu. For awhile it worked only on a couple of speeds, then stopped working entirely. I replaced the blower resistor and this fixed the problem for about a...
The blower motor, as you have probably seen, is under the dash on the passengers side. While in Park with the parking brake applied:
Turn the Key On with fan blower set to High. Locate the blower motor and wiggle the electrical connector. If this brings the blower motor to life, a new blower motor is needed. This, if applicable, is a common failure that matches your symptoms. The new blower is simple to replace, although it is never fun working under the dash.
If you have a 12 volt test light or DVOM (multimeter) you can check for power at the electrical connector. You should have battery voltage (12+) with the blower set on high. Always use a known good ground when testing for power. If you have power (key on, set to high) and no blower operation the blower motor needs replacing.
The resistor you replaced is a very common failure on these.
Give me an update.
Nov 15, 2008 | 2002 Chevrolet Malibu
Atlas Model Railroad Atlas 10000706, Ho Scale, Alco C425 Haven 2551 Logo
130 people viewed this question
Top Atlas Model Railroad Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Atlas Model Railroad Toy Expert? Answer questions, earn points and help others
