Question about Pioneer VSX-454 Receiver
Crakling noise from left speaker after warm-up
    Brigadier General:
  • 8,546 Answers
Is it all sources, or just analog ones? Does it change if you manipulate any knobs or switches.
Turn it off and operate every control throughout its range to wear through oxides that may have built up through non-use. The signal has to travel through every switch at some point.
Posted on Apr 03, 2011
I have a Protron PLTV 32' LCD and its making crackling noise out of the right speaker.
Hello
If the crakling sound is from only comes from right speaker, it will be a speaker trouble. In some speakers, the voice coil will get damaged, and if so, this kind of distortion will occur. Replace the speaker with same type and diamensions. Note the 'Ohm' [resistance] of the coil, which will be marked on the speaker. There will be markings like 4Oms 6W, 8Ohms 10W or so. Choose the correct value of these. That is the only thing should mind when choosing speaker. OK.
Apr 20, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
When I turn on my fender hot rod deluxe 40W, even before plugging in my guitar, it crakles and makes noises constantly. I've had it for over 5 years and I play it maybe 1 hour a week. Is it a tubes issue?...
This is likely either a tube issue OR one with capacitors.
You need to characterize the loudness of the noises versus the settings of the controls as part of troubleshooting...
You can try tapping each tube with a pencil to see if one in failure will reveal itself.
Jun 16, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My computer speakers are popping and cracking.
Check connecting and Volume settings. Speakers might be blown. This happens when high volume is played and speaker tears causing a poping and crakling sound
Mar 24, 2010 | Altec Lansing Multimedia Computer Speakers
How do i check if my amp is still good?
first make sure that you have power check the red thick wire, and the remote wire with a voltmeter if its ok then disconect the rca plugs now get a pair of rca wires plug one end to the amp and touch the other end if it makes noise your amp is good ( please be very carefull as it will make a loud noise on the speakers when you touch the other end if the amp is good) good luck
Dec 16, 2009 | Car Audio & Video
Amp noise. when bike is off speakers sounds fine.
It may be your plugs and or wires. Make sure your plugs are the resistance type and the plug wires are shielded.
Sep 28, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
My speakers snap, crakle, pop like Rice Krispies.
make sure the power to the TV and the receiver are not on the same ground. Move the TV power cord to another outlet, or get a power conditioner instead of a power strip.
Jul 26, 2009 | Audio Players & Recorders
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
55 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
