Question about Bosch & Tankless LP Hot Water Heater
I have a Bosch Water Wizard 10P - have no hot water, no water comes out the hot water tap, can't light Pilot Light, not sure where to start would love a step by step diagram how to start pilot light - ignition switch not working, where do I look for pilot light? How do I get hot water?
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Before calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 03, 2011
  • Anonymous May 13, 2011
    Upvote the help
Bosch 10p hot water system off button wont pop out!
Wiggle the button while pushing and releasing, maybe it's caught on the casing it's in.
Jun 13, 2012 | Water Heaters
Hi I have a Bosch water wizard 10p & although i have the heat turned up to the highest it is still not hot enough! I was wondering if there was another way of increasing the water temp?
Open following link for Bosch troubleshooting resources:
Typical Bosch 10P manual shows temperature control illustration on Pg4, and includes low water temperatures on troubleshoot on Pg6
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
Water flow rate too high, low gas pressure, faulty thermostat.
Two other things might be causing problem
Crossover:
http://waterheatertimer.org/Crossover.html
Lime build-up
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Jun 15, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
Best place to start is your manual.
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch & Tankless LP Hot Water Heater  Logo
3,130 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
