Question about Janome Sewing Machines
I need a threading guide for Janome 744d overlocker. i did not get\r\na manual with my machine at time of purchase
  • 794 Answers
Hi nhclark1,
I have a video here from You Tube that you might find helpful in threading your Janome 744d. This is not the exact same model, however, very similar to your machine.
For the manual, you can click on this link to download it. You may also contact Janome directly so they can send you the instruction manual for your machine. Call them from Monday through Friday 8:30AM - 5:00PM EST, 1-800-631-0183, ext. 774.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 03, 2011
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Janome New Home sewing machine instruction manuals
Make It Handmade Threading Your Serger or Overlocker
Nov 25, 2016 | New Home Sewing Machines
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
Need user manual for Janome overlocker mylock534d
try janome website first about a manual
sewingpartsonline.com
sewusa.com
sewingmanuals.com
May 11, 2012 | Sewing Machines
Hi. About 5 years ago I purchased a Janome 744D Overlocker which I have only used once because the thread on the underside keeps snapping, and the needles keep breaking off. The foot is also very touchy...
Yes, overlockers sew fast, usually 1500 stitches per minute and with a blade in action alongside the loopers so there is a lot happening. Keep all pins well away from the seam edge, contrary to normal sewing machine techniques, if you pin two layers together, then place the pins parallel to the fabric cut edge at least 2 inches away from the edge so the pin goes nowhere near the foot or blade.
Check whenever you use it, that you firstly extend the thread aerial up to full height, you need to ensure the threads can flow smoothly to the tension dials as the thread will stream off fast, even the slightest catch of a thread will snap one, throw your tension out or damage a looper.
As you've had it all this time and not used it, why not consider investing a few dollars more and go to a class on overlockers, and learn how to thread it up for three, four, rolled hem and using the differential feed. If there is no class options in your area, then try the Janome dealer near you and see if they would consider giving you a a little lesson on using it. You could also check out the videos on You-tube or read some pages from Debbie on www.sewing.about.com, she has several pages on sergers (USA name for overlockers), explains the needles, threading, different techniques and maintenance. Or check out your local library for any books on sergers/overlockers, there are several good "how to" guides out there that would certainly help you get started.
Unfortunately there is no way to slow the speed to half speed, just practice with lots of fabric scraps at first, to get used to the sensitivity of the foot control. If you do dressmaking but aren't sure where to overlock or which seams you could only overlock, then consider just doing a three thread overlock around the edge of each fabric piece before you commence assembling the garment, just do your notch markings another way such as chalking them or using water soluable marker pen as the blade will cut away your outwards notches.
My other suggestion would be to make a simple sweat shirt on it using the 4 thread stitch and not touching your sewing machine at all. Once you've made one, you'll soon be wizzing them up in 30 mins, so quick to sew knits on an overlocker. Some of the commercial patterns are marked as suitable for sergers, look for one of these to try.
I hope this helps you to master your overlocker, a lesson or class would help you with the steep learning curve at first.
May 22, 2011 | Janome Sewing Machines
I do not know how to rethread my Janome overlocker
look on you tube as there is a guide video. Once you have it threaded, tie the new thread to the old one and pull it through so you don't have to start again. You can even sew slowly and ease the know through the guides.
overlockers are fussy about start position of tail of thread, so hold it correctly when you start
Aug 10, 2010 | Janome Harmony 9102D Mechanical Sewing...
How do i thread a janome overlocker
there's a good you tube video and threading an overlocker
Jun 01, 2010 | Janome MyLock 634D Mechanical Sewing...
Janome mylock 744D overlocker
Have you tried youtube for 'how to' videos? I just found this one that might help. Good luck. http://www.youtube.com/watch?v=JyrAhSQAEeY
Mar 22, 2010 | Janome MyLock 644D
I need a user guide for a janome finesse overlocker model 534D. Free download if possible.
Sewingmachinesplus.com has heaps of manuals - I purchase a Janome 534D Mylock overlocker from here for $11 Aus. The site is American but you can pay with paypal. Immediate download on payment. Definitely worth it.
Apr 01, 2009 | Janome Sewing Machines
Janome 184D - thread tension
You may need to purchase a Gathering Attachment
Part No. 200 217 101
BUT be sure it is suitable for your model first
(I am unsure which one you have)
Thread tensions are set at manufacture to all = 3 for standard work, your manual is generally helpful for many answers.
The "Janome Overlocker Sewing Guide" is a very detailed publication and has this to say about Gathering without any additional attachment.
Oct 30, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
239 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
