Question about Targus Computers & Internet
The targus dvd model number adv01us is plugged into the usb port on my laptop.. I put in a DVD, but I keep getting a message to insert a dvd.
  • 27,725 Answers
Make sure that the cd/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 03, 2011
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
Dvd external thoshiba NB550D
You want an external dvd drive? Any type of external dvd drive will work because you will just plug it into the usb port.
If you want an internal dvd drive to replace the one you have inside the computer then just to to ebay and put your computer make and model followed by dvdrw drive in the search. Or you can remove the one screw on the bottom of the laptop that holds the dvd drive and pull the drive out. You can also do a search on ebay for the model number on the dvd drive.
http://www.ebay.com
May 13, 2012 | Computers & Internet
Problems installing printer Samsung 315 clp to laptop windows7
Do the following:
1. Insert the CD/DVD that comes with the printer into the cd/dvd drive in the laptop.
2. If you do not have CD/DVD then download the driver/software from Samsung website.
3. The software should start installing. If not find setup.exe and double-click it.
4. During the installation it will ask to connect the printer. Then plug the printer to the wall socket and turn it on. And insert the USB cable into the printer USB port as well as into Laptop USB port.
5. The printer will be detected automatically and necessary driver will be installed.
6. Wait for the installation to finish. Now you can use the printer and print document and photos.
Aug 09, 2011 | Computers & Internet
Bought a Targus slimline usb dvd player to attack to my acer netbook. It will not play any dvd's. It keeps saying my disks may be corrupt. What do I do?
There is either a problem with your discs or the targus unit so first:
put in a disc and if it says that it's corrupt then take it out and try to play it in something else that you know works.
Then if it does play, it's the targus unit's fault. If it does not play then your discs are bad.
May 10, 2011 | Targus 8x External DVDROM Drive External...
Targus External USB ADV01US not recognized by any PC, XP, Vista, or Win 7. Multiple USB Cables used. No power supply required by the drive, powered by PC.
Could be a disk problem of course. Make sure you try a desktop and not just laptops, they do not always provide enough power on the USB ports. Or try an external USB hub with a poer supply.
More ideas on external HDD troubleshooting.
Sep 12, 2010 | Computers & Internet
The drive is not registered with my machine after I connect it.
u dont have any specific drivers that came with the Targus dvd?
..mabe the generic driver is not exepted!
..or ur usb port is not configured properly!
...do u have usb 2.0!
...did u tried on other ports!
...try to force usb 1.1!
...last step: in bios, try to putt usb dvd , or usb , (or anything similar), to boot from, (make sure u have a proper disk inside the dvd.)
if it worked (and its not simple, u need to make many tries) , then its driver problem, and in xp pro, every thing can be fixed ;)
gd luck
Dec 30, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
Targus CD/DVD does not show in directory
try to use another usb cable for your external dvd drive>>>> then if it's not working again try to check the bios setup if the optical drive is enable. if the setting is disable please change it to enable>>> if still not work back on where did you bought it>>> maybe it is defective...
Dec 14, 2009 | Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD...
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
Computers & Internet Logo
1,186 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
