Question about Zanussi Washing Machines
  • 1,462 Answers
Brushes are on the motor at the opposite end to the pulley. job can be done with motor in situ, but you will find it easier to take motor out.
however, how do you know they need replacing as you obviously have not tested for continuity thro brushes to commutator?
Posted on Aug 05, 2008
Hi, my zanussi nexus fl884 wont spin, I cleaned the fluff filter but still wont spin
I would check the brushes on the motor. If these are worn that can stop the machine working full spin under load
Jan 11, 2018 | Zanussi Washing Machines
E40 fault on zanussi washing machine is it worth repairing or to buy a new one 8-9 yrs old ?
A Zanussi E40 error usually indicates "Door open.Check interlock and associated wiring check door latch,check module and connections." However, what most people don't know is that most manufacturers route the poser to the door interlock through the same curcuit that powers up the carbon brushes on the motor. So if your motor brushes are worn down, the door won't lock. Your machine is about the right age for its brushes to be worn out, so I would check this out first. Motor brushes are cheap, easily available on Ebay and fairly easy to fit. Take the current brushes out, if they are less that three quarters of a centimeter long, changing them is a highly likely fix for your problem
Oct 31, 2015 | Zanussi Washing Machines
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Jul 01, 2009 | Zanussi Washing Machines
Softener still in dispenser after wash cycle
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me
For more help go to live chat.
Jan 30, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry jetsystem 1200
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
212 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
