You probably need to enable the aux input. To do this, turn the deck off and then enter the function menu. Set the aux input to on and you should be good to go.
Go to menu or inputs _change to input jacks you connected DVD/Game.too. For example If you use Aux change input to Aux,---if it is Video1 then change input to Video1.
Make sure that "AUX" is turned on on the menu. Some Pioneer radios have a front aux, a rear aux, a rear steering wheel control jack, and an aux through the IP-BUS only. First, make sure that if there is an auxillary port on the back of the unit, that it isn't the steering wheel control plug by accident. Second, front auxillary inputs on Pioneer radios NEVER need to be turned on in the menu, only inputs on the back. Any back inputs are turned on in the main set-up menu when the radio is first turned off. Hope this info helps.
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Are you sure it is an AUX input?
According to the Manufacturers Specs, the AUX, is an optional accessory.
There is a Pre-Amp connection, which would be an output, hence causing the problem you are having.
Best of Luck.
