Question about Fisher and Paykel WL26CW1 Top Load Washer
What is the error code 249 on a Fisher & Paykel Washer WL26CW
SOURCE: new fisher and paykel washer WL26CW fault code 245
the drain pump impeller is seized; you just need to turn it a bit and will work just fine afterwards.
Posted on Mar 26, 2010
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
  • 30 Answers
SOURCE: Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
Posted on Jun 08, 2010
  • 713 Answers
SOURCE: i have a #37 code (pump blocked error) on my
Hi just read your posting.Now 1st I need to know which type of pump you have on your machine,Please look underneath the machine for me to the front right.You should see a red or black fan.This is your pump.If you do not have a red or black fan attached to your pump then you have the other type with is held in by 2 screws.Please reply and tell me which pump you have and I can guide you throe the removal and cleaning of the pump.Also is your machine draining into the laundry sink or elsewhere?
Posted on Jun 27, 2010
tunde007
  • 2382 Answers
SOURCE: fisher and paykel model WL26CW1 what is fault code
Hi, although the fault code 249 does not exist in the repair manual and in all Fisher and Paykel washer series. But i have come across different people who had the same fault code 249 on this same washer but the code was associated with different problem on the washer. While the code was associated with spinning problems on some, it was associated with draining problem on others while some complained about not working at all.
So you need to get a repair tech around to check the washer out and determine the main problem with it before proceeding to repair. You just have to ignore the non-existent 249 fault code
Posted on Dec 24, 2010
Fault 9 flashing on wl26cw fisher and paykel washer
Fault 9 LAH HIGH CURRENT FAULT The low ambient heater is drawing more current than expected. Either the heater or wiring is faulty.
Primary Action
- Check the wring and connections at both heater and power module.
Secondary Action
- Check heater resistance. If not within limits replace heater.
Aug 03, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Error code 3
Error code 3
Your motor controller module is faulty.
Has a memory error & needs replacing.
Jan 26, 2013 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
New fisher and paykel washer WL26CW fault code 245
Jan 25, 2009 | Fisher and Paykel WL26CW2 Top Load Washer
Fisher and Paykel WL26CW1 Top Load Washer Logo
250 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
