Question about Panasonic KX-T7730 Corded Phone
Panasonic KX-TA624 system
I just bought a house in Florida with the above system and have called all around to get it programed with no luck. Is this a servicable system or should I scrap it?
Try
www.twacomm.com/catalog/model_1490008.htm
They sell the manual for the system I think
Posted on Aug 08, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Ttry the manual first you probably don't have it
http://www.retrevo.com/
Posted on Aug 07, 2008
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
How can I get the music on hold to work on the Panasonic Advance Hybrid System KX-TA624?
On the cabinet, there is a jack marked EXT MUSIC. You plug in an audio source to the jack and then go into system programming and turn it on in program 111.
Carl
Feb 04, 2011 | Panasonic KX-TA1232/KX-TA624 phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Programming numbers into telephone
    to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
    <pick up the receiver>
    <the number you want to have as speed dial>
    <the number you want to dial>
    <press the square shaped key next to 0 and 9>
    <wait for dial tone to return>
    <hang up>
    To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
    For example
    <pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
    This will mean that when you press the square key and 1, it will dial 555555555
    Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    90 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
