Question about Briggs & Stratton Plumbing
I am using a Monarch BSGF-8 pump with Brigs and Stratton engine to pump a septic tank. It worked well for one septic, I moved it to another and now it won't pump, won't **** at all. Any ideas?
  • 3,740 Answers
The pick up hose is not seated /connected properly to the pump or... there is a hole in the pick up hose above the water line. These are the only 2 things that cause this symptom unless the inlet for the pump is covered completely with debris. Check and see if some one lost the hose connection fitting gasket during the move between tanks. If your using a press fit hose to the pump... wrap it with tire wire or a large clamp so that it fits tighly onto the inlet. Check to make sure the hose is not dry rotted and cracked at the connection point also.
Thanks for choosing FixYa,
Kelly
Posted on Apr 03, 2011
  • Zorro Dec 02, 2011
    To simplify the above answer - you may have a air leak in the suction hose - fill the casing with water and turn on the pump if the waster is blown out and stops pumping you have an air leak in your suction line.
How do the septic system inspected?
The septic system inspection include following steps:
locating the septic system
Sludge level test
Checking last pumped details
Drain lines inspections
Apr 15, 2016 | Plumbing
220.brigs and Stratton oil how much insump
A small qt bottle of SAE 30 wt oil, of ANY brand is fine for use in lawnmowers. The tolerances for the piston ring and cylinder are not so close to warrant more expensive synthetic blends. A simple std grade (cheapest) 30 wt is fine. It is a good practice to drain and refill your lawnmower engine before each cutting season, replace the air filter, and spark plug. Carburetors tend to foul so empty the gas tank at the end of each cutting season by letting the mower run out of gas... empty the float bowl, if it has a drain screw... this will keep varnish and gum from forming when you store it. Keep a spare cord on hand as they break when you least expect them to and when you need to use the mower. Hardware stores sell replacement cord, just cut to lengths as needed.
Oct 11, 2014 | Garden
Have a monarch type a 1/2 hp model be-e50 effluent pump which runs constantly and will not **** off what are some of the reasons ?
If it is a submerged pump, it needs a "float switch", This is a (usually) a ball made of plastic that floats in the liquid and senses the level gets to a certain height it will allow the pump to run until the level is down below that height.
Aug 30, 2014 | Cars & Trucks
Septic tank pump is brand new. Our alarm just went off and we looked in tank and the water is very high.... could it be a faulty pump?
could be. could also be a clogged output line, a blockage in the septic field, even a sock stuck in the intake of the pump.
Jul 31, 2013 | Plumbing
Septic tank cleaning
To clean a Septic Tank is a very difficult job for everyone nobody likes that bad smells.But there is a better solution or answer of cleaning septic tank is on YouTube where I have seen a video that showing how to get clean and smell free septic tank .That video was awesome and the product which showing in the video works very fast and give effective result in very less time.I think you should buy that product.
Watch this Video: https://www.youtube.com/watch?v=A_WnG8UQPmQ
Jul 01, 2013 | Plumbing
Septic effluent pump loses prime
DONT TRY TO EMPTY THE TANK, RAISE THE FLOAT LEVEL. THIS STOPS THE PUMP FROM SUCKING AIR WITCH CAUSES THE PUMP TO LOSE PRIME,
WOW THAT WAS A EASY ONE. ....NEXT
OH AND YOU MIGHT NEED A CHECK VALVE ??
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
Sep 11, 2012 | Monarch Pumps BE-S75 Wastewater Pump...
Plumbing Logo
143 people viewed this question
Top Briggs & Stratton Plumbing Experts
Donni Steen
Tom Chichester
Are you a Briggs & Stratton Plumbing Expert? Answer questions, earn points and help others
