Question about JVC Audio Players & Recorders
Can the cable that connects to the stereo go bad? I have not been able to get sound from the turntable. Plugged it into three different receivers and nothing. Any ideas?
    President:
  • 2,080 Answers
I assume you are refering to the RED and WHITE ended cables that run from your turntable's AUDIO OUT (Left and Right) jacks to the stereo's PHONO IN (Left and Right) jacks on the rear of your stereo receiver.
The answer is yes, they can fail. Like any electrical wire they can develop internal breakages in the conductors over time especially if they are very old or have been handled a lot.
This should be a very easy problem to troubleshoot since new patch cords are readily available at any electronics store for just a few dollars.
Before you go out and buy new cables though, just make sure you have the stereo input set to PHONO and the volume turned up to a reasonable level when you are checking the signal from the turntable.
I am also assuming of course that the other stereo functions like the TUNER and the TAPE PLAYER inputs work fine and you can hear good sound coming from the speakers when you select those.
Please comment back here to this page if you have any questions, are still having trouble, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on Apr 03, 2011
  • Joe2
    Joe2 Apr 03, 2011
    If your turntable's audio output wires are hardwired into the turntable, meaning they do not plug into jacks at the back of the turntable but instead lead directly inside the casing, then the solution to your problem may be a little more involved.
    If they are non-removable audio output cables, and you are certain they are the cause of the problem, then you will have to disassemble the turntable in order to solder in new output cables onto the output terminals inside. This is not overly difficult, but it does require a few basic tools and some electrical safety precautions.
    Please comment back here if this is the case and I will provide additional instructions if required.
    Thanks.
    Joe.
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    How to hook up a turntable to a pioneer vsx-1019
    receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
    http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
    May 02, 2011 | Audio Players & Recorders
    Buzzing sound in my speakers when I switch to the phono stage
    It is a grounding issue with the turntable most likely. Some turntables came with a ground wire that you attached to the receiver. You can also try a power strip that has a line filter incorporated to get rid of the hum. Check the local stereo shoppe to see if they carry them.
    You may also want to replace the audio cable that connects the turntable to the amp with a good quality shielded cable. If it has bad shielding it will pick up electrical interference and even radio interference as well.
    Turntable inputs on receivers have a preamp built in and the gain for each type of pickup is different. The pickup is either ceramic or magnetic and if I remember correctly, the ceramic pickup needed more gain than the magnetic one. The preamp will definitely make a ground hum a lot more audible.
    Cheers and good luck.
    Dec 20, 2008 | RME Intelligent Audio Solutions RME...
    Home stereo audio problems
    Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
    Sep 27, 2008 | Audio Players & Recorders
    How to hook up a turntable to a stereo
    you might need a pre amp in between the turntable and the kenwood.. but you'll connect this on the aux IN.
    Aug 05, 2008 | Audio Players & Recorders
    Distorted sound.
    Your turntable is a preamp. Your amplifier might be going bad. did you connect it into phono? dont connect it into the cd or dvd input because those wont work.
    May 11, 2008 | Technics SL-1200MK5 Turntable
    Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
    The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
    You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
    Apr 05, 2008 | Televison & Video
    42 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Henry  Thomas
    Henry Thomas
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
