Question about NAD C350 2-Channel Amplifier
Replacement remote control required for NAD C350!! mail@alder.cc
    Brigadier General:
  • 8,546 Answers
NAD C350, everything works after i replaced many blown parts except it has no sound output from any channel, just need some ideas on what to check for faults. thanks
With no background on the original problem and no details regarding what parts were replaced how can anyone answer the question?
What exactly does it mean if 'everything works' but it has 'no sound output'? As a two channel amp that would be its ONLY function.
The root cause for 'no sound' could be something as simple as a misplaced control (Tape Monitor?) or missing pre-out/main in links. It's in the manual.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/NAD-C350-Amps-manual/id/8043dj589/t/2/
Jun 01, 2011 | NAD C350 2-Channel Amplifier
My NAD C350 won't allow me to switch input source - permanently on "AUX". Any idea as to cause/fix? Also I need to switch out my power 220v power supply for 120 (US). Would appreciate guidance here as...
Can't help on power problem, but the other sounds like an IC has failed that controls input selection. If you are going to do it yourself you will need a circuit diagram to find the IC.
Dec 20, 2009 | NAD C350 2-Channel Amplifier
No power in NAD c350
Hi...
Have you checked the rectifier diodes / bridge rectifier . Most DMMs have setting where you can test for forward voltage drop on a diode
0.300- 0.800v depending on the type. If it reads nothing , swap the meter leads.
Also check the leads coming from the power transformer and see if there's continuity. THey will read low value ohms
Apr 26, 2009 | NAD C350 2-Channel Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
Nad C350 schematic or service manual required
I don't know of the availability of the schematics outside of service centers. Is there a specific problem? I have access to the service manuals but can not by contract send them out.
Dan
Jul 15, 2008 | NAD C350 2-Channel Amplifier
NAD C 340
Power surges and lightening can reak havoc. It may just need fuse replacement
Apr 12, 2008 | NAD C350 2-Channel Amplifier
NAD C350 2-Channel Amplifier Logo
678 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
