Hi, I have a Phillips DTR-7200 HD set top box. There is no image on the screen, expect I can see that it is stuck on a channel. When I try to change to a different channel, the audio changes to the new channel but it remains stuck on channel 47 with no image. Could you please help?
SOURCE: Digivox DV3 cable box
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Posted on Aug 31, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: set top box - service list changed
yo, try this, i just bought the same STB and had the same problem. So far this has fixed it (fingers crossed).
http://www.teac.com.au/pages/hdb842softwareupgradever161008
cheers
Chris
Posted on Dec 23, 2008
SOURCE: MANUAL FOR HD SET TOP BOX
Try this link. Ijust downloaded the manual from here myself.
http://www.dgtec.com.au/arbitrage/pages/134/DG2000A+UserManual.pdf
Regards
Graham
Posted on Jul 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: LG LST-5100P set top box
Hi Rod,
Thanks for Using FixYa. If its a 4:3 normal TV or a wide 16:9 TV then you can view high definition picture by using the ARC button on your remote control to change the wide mode(Auto,Letter Box, Pan & Scan). Also check its free user manual for more information.
LG LST-5100P User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 22, 2009
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
Adding a hd set top box to 55pp8620
hdmi id the best way to go
see if it is high defition input "HDMI" or s-video or av hook ups are not high def
Mar 15, 2009 | Philips Televison & Video
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Mar 02, 2009 | TVonics Televison & Video
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The image expands off the screen of my HD tv
Look in the menu for an image adjustment option. This is used to center or adjust the given image. Try a different type of connectiong from the cable box to your TV. ie; if you are connected by component connection, try AV or HDMI to test. If that doesn't work, look at the cable box settings (call your cable company for instructions) or have the box replaced if defective.
This is common for PC connections but not for cable.
Dec 21, 2008 | Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Black bar at top of screen
probably your cable box, request another one from your provider
Oct 02, 2006 | Panasonic TH-37PX50U 37 in. HD-Ready...
Open Questions:
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
