Question about Garden
My Fs 45 will not start. I am unsure if i am even starting it properly but i think i am. It was purchased over christmas and has only been used twice. There is fuel in it and was working fine the last time it was used - about a month ago.
    Novelist:
  • 111 Answers
The fuel could be stale. I would empty the fuel tank and put fresh fuel in it. Make sure the unit is in the ON position. On the handle there is a switch. ( I is ignition (to start) and O is off (to kill the unit)). Then pump the primer bulb a few times to make sure there is no air in the fuel lines. Then move the choke lever up into the choke position. Pull the starter cord no more than about five times, it should try to start. Then move the choke lever down, into the off choke position. You should pull the cord a couple of more times and it should start right up. If you have put the choke lever in the on position and pulled it a few times it could be flooded. To clear out the cylinder and get the unit running at this point. Turn the choke to the off position and pull the unit a few times. Depending on how flooded the unit is it could take quite a few pulls.
Posted on Apr 03, 2011
Konica minolta buzhub c360 giving error c1183
Elevate drive malfunction
<When FS-527 is installed> • During downward movement, the tray 2 upper limit sensor (PS24) is turned OFF and the tray 2 lower limit sensor (PS21) is turned ON. • The elevate motor (M15) lock signal remains set to H for a set period of time while the elevate motor (M15) is turning. • The tray2 upper position switch (SW2) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. • The tray2 lower position switch (SW3) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. <When FS-529 is installed> • When the exit tray is moving up: When the tray up/down motor (M2) starts rotating with the output of the tray lower limit sensor (PS6) being ON, PS6 is not turned OFF even after the set period of time has elapsed. • The paper surface detect sensor/1 (PS2) or the paper surface detect sensor/2 (PS3) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. • When the exit tray is moving down: The tray lower limit sensor (PS6) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. Remedy When FS-527 is installed: 1 Check the connector between M15-FSCB PJ4 for proper connection and correct as necessary. 2 Check the connector between PS21-FSCB PJ21 for proper connection and correct as necessary. 3 Check the connector between PS24-FSCB PJ16 for proper connection and correct as necessary. 4 Check the connector between SW2-FSCB PJ3 for proper connection and correct as necessary. 5 Check the connector between SW3-FSCB PJ3 for proper connection and correct as necessary. 6 Check the connector of M15 for proper drive coupling, and correct as necessary. 7 PS21 I/O check, sensor check. 8 PS24 I/O check, sensor check. 9 SW2 I/O check, sensor check. 10 SW3 I/O check, sensor check. 11 M15 operation check. 12 Change M15. 13 Change FSCB.
When FS-529 is installed: 1 Check the connector between M2-FSCB CN12 for proper connection and correct as necessary. 2 Check the connector between PS6-FSCB CN5 for proper connection and correct as necessary. 3 Check the connector between PS2-FSCB CN4 for proper connection and correct as necessary. 4 Check the connector between PS3-FSCB CN4 for proper connection and correct as necessary. 5 Check the connector of M2 for proper drive coupling, and correct as necessary. 6 PS6 I/O check, sensor check. 7 PS2 I/O check, sensor check. 8 PS3 I/O check, sensor check. 9 M2 operation check. 10 Change M2. 11 Change FSCB.
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Sep 17, 2009 | Garden
Stihl FS 45 throttle problem
its a self fix just get a new one it will come complete
Jul 24, 2009 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
GE Over-The-Range JVM1653BD Error code -FS-
"F5: Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds."
It may be excessive moisture on the sensor, or it may short from time to time internally, then "unshort" when it cools or dries.
Until it fails consistently, I probably wouldn't worry about it.
If and when you or someone you know want to check and/or replace it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 05, 2008 | GE JVM1653 Microwave Oven
Transmission
Automatic transmissions can last a very long time, if properly cared for, and not overworked/overheated. Proper fluid/filter changes are needed!
If you are unsure, you should take the car to a mechanic, and have them inspect the transmission. If the seller rejects this idea, then I would hesitate the purchase of this vehicle.
Brian
Jun 24, 2008 | Nissan 200SX Cars & Trucks
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
