Question about Kitchen Ranges
The oven and top right ring on my beko dc543 oven not working al other rings are?
  • kennymac69 Jan 01, 2009
    I have the same problem, please help.
    President:
  • 1,462 Answers
Check that links on the mains connection block are tightened down
Posted on Aug 05, 2008
Beko HII64403T induction hob, the left 2 rings packed in tonight, they went from 6 to E then turned off. the 2 right rings continued to work.
contact BEKO they will know why they did what they did and will know better what the fix will be . sounds like the 2 units might have burnt out due to not having the pots on them .
Nov 08, 2016 | Kitchen Ranges
Why is mu beko cooker building up steam in the over and making food all soggy comet have told me not to cook food with any water in but thats impossible
You do not normally cook with water inside the oven, ovens are for dry cooking only, rings are for boiling water and used for cooking this style
Jul 12, 2011 | Ovens
Have replaced wax ring on three seperate occassions, and the Mansfield Alto Biscuit Round Toilet Bowl still leaks from underneath. New construction with hardwood floor and the floor is level. Tried looking...
Have you thoroughly warmed the wax ring before installation? I don't know the exact temperature required, but the rings tend to split apart rather than form a nice seal if they are a bit cool. 65 is definitely too cool. I have put the ring in the oven on the lowest possible setting for about 30 minutes. Or a closed car in the sun can work well too. Good luck, Al K
Apr 18, 2011 | Home
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
No timer
Yes sorry to say that your oven wont work you will have to have a new timer fitted, but first make sure that having a new timer fitted is not more expensive than buying a new cooker
Sep 06, 2009 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Beko dc543 oven and top left top right bottom right hobs not working bottom left hob is working and so is grill i have checked all terminal wires and all ok i had this problem before under...
    I AM NOT AN ELECTRICIAN ! But i have had the same problem of the oven and the back right ring not working and have found the cause of this. For some reason there is a thermal fuse running inline on a live wire inside the cooker if you feel competent yourself in replacing this fuse you will save a good deal of money on call out fees, here is how to do it. SAFETY is the crucial, First of all isolate the power source to the cooker, pull out cooker so you can get access to the back of the cooker, remove the 9 screws ( i think there is 9) to remove the back plate from the cooker, this is quite heavy because there is a small block of concrete fastened to the bottom left hand side of the back plate, looking at the inside of the cooker on the right hand side you will see a white wire which has been secured via a small screwed clip, this wire has a transparent sleeve covering the thermal fuse, remove the sleeve by sliding it up or down the wire, check the fuse by with a meter just to be sure, if it is blown cut the fuse out. replace fuse the same way it was fitted. replace the sleeve and fit the back on the cooker SAFETY FIRST switch on power and try oven and back ring, mine works fine. like i said at the start i am not an electrician, but i can not understand why there is a thermal fuse running inline to the oven which is linked the back right hob. all the best folks Hobbo from Chess.
    Mar 23, 2009 | Jenn-Air JES9860 Electric Kitchen Range
    Only one ring of the double ring element works
    You have faulty regulator, or the element is faulty., not sure how you access the inside.
    Hope this helps.
    Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
    Kitchen Ranges Logo
    164 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
