Question about Watches
I want to set the watch to beep or chime on the hour.
  • 2,334 Answers
When you are setting alarm, there will be visible sign of loudspeaker or bell. Toggle with buttons and when the sign is visible in normal mode (ordinary time showing mode - everyday wear) the beep will alert you every hour. Be aware - there are hundreds of people asking how to disable this function, simply because it gets annoying after a few days - it works during the night time as well.
Posted on Apr 03, 2011
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
I have an alarm chrono watch from walmart and it beeps every hour, even though I've turned the alarm setting off. How do I make it stop?
I so have the same problem. I have the same velcrow chrono watch from Walmart. I was going to set the date on it when I accidentally set the hourly chime. I annoys everyone, especially when it goes off every hour.
Oct 05, 2010 | Watches
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
Turning off hourly beep on Unlisted mode
and more simpler solution is found in the user guide:
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
To turn of beep, hold Reset buton and press Mode button, When all 7 day flags show, the hourly chime is on. When no day
flags show, the chime is off. Enjoy the silence :)
Apr 13, 2010 | Bulova Watch
How do i set the hourly chime on the timex ironman flix watch?
Press Mode till you are in Alarm setting
Press and hold split/start button till you hear the double beep. You should also see a small clock icon above the last digit of the seconds... you are all set. Repeat to deactivate hourly chime.
Nov 12, 2009 | Timex Ironman Flix 100 Lap Unisex Watch
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Watch is Beeping loudly on every hour!
While pushing and holding the RESET button in, press the START button to toggle between CHIME ON/OFF.
Mar 13, 2009 | Bulova Men's Watch
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
I want to know how to turn on the hourly chime on timex ironman 30 lap watch
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Dec 14, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Innovage Gear wristwatch beeps every hour
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Mar 11, 2008 | Watches
Watches Logo
132 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
