Question about DeLonghi DCG39 Electric Blades Grinder
How to oppen a coffee grinder model DCG39 if i have to repair it.\r\nIt,s a Delonghi . Thank you.
4 Suggested Answers
  • 279 Answers
SOURCE: How to select grind courseness for a DeLonghi DCG39 grinder
Go to delonghiusa.com. customer care. manuals. They have yours to download.
Posted on Sep 18, 2009
SOURCE: Delonghi DCG49 is suddenly quieter and will not release coffee
Had this problem with my burr grinder, coffee (or something else) is clogged between the burrs and the output chute, so new coffee can't feed in from above. You can try a few things:
1. Unplug and try to dislodge the blockage from underneath with a toothpick.
2. Disassemble and remove the blockage.
3. I've had luck with drizzling a little bit of cooking oil on to the burrs,letting it soak in a while, then running it, the clumped coffee came loose. It made a terrible mess in the bin, but I ran a couple cups of beans through and it cleaned up the oil.
Good luck~
Posted on Feb 12, 2010
Testimonial: "You were right about the clog. I tried the white rice fix seen elsewhere and it's grinding perfectly again. Thanks."
SOURCE: My DeLonghi KG79 coffee grinder
I should imagine one of the safety switches are not closed. The lid of the maker must be on and the filler has to have its cap on and inserted in the machine.
Posted on Aug 08, 2011
DeLonghi DCG4T Electric Burr Grinder
go to www.repairclinic.com or www.appliancepartspros.com
God bless you
Jul 19, 2012 | DeLonghi DCG4T Electric Burr Grinder
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My DeLonghi KG79 coffee grinder has stopped working after one grind. When the on button is pressed nothing happens. I tried changing the plugs fuse... any thoughts? cheers Kev
Mar 19, 2011 | DeLonghi KG79 Grinder
Good luck~
Feb 09, 2010 | DeLonghi DCG49 Electric Burr Grinder
Overloaded grinder no longer turns after puff of smoke!
the shear pin, which goes through the grinder blade base and the motor shaft has 'sheared' off the protect the motor from overload. The metal bits of the pin need to be removed from both the grinder part and the shaft, a new one inserted. It is a 'pressed fit', so it will be hard to remove.
After the bits are removed, a common 'roll pin' of the proper diameter should be a suitable replacement
Feb 04, 2010 | DeLonghi DCG39 Electric Blades Grinder
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Aug 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Grinder is not working
http://www.delonghi.com If your machine is still under warrenty they will tell you by numbers on the bottom. If you have receipt, even better. They will send you a new machine for shipping costs only. If machine is out of warrenty they will tell you where to get repaired. Very easy to deal with.
Jun 07, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLongi coffee mill #DCG-4TB
DeLonghi PARTS AND ACCESSORIES
1 (800) 865-6330.
8:30 a.m. – 5:00 p.m. (EST) Monday through Friday.
Oct 24, 2008 | DeLonghi Electric Coffee Mill Grinder
Aug 18, 2007 | DeLonghi DCG39 Electric Blades Grinder
DeLonghi DCG39 Electric Blades Grinder Logo
49 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
