Question about Gucci Ya114202 114 digital watch
Didgital watch screen went blank & its making an alarm sound
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
I have a casio a158w alarm chrono, the screen went blank, opening up the back, is the battery the big round thing in the middle that seems to be stuck in place??? it takes up most of the inner works of the...
Yes, the big, round thing in the middle is the battery. To get it out you need to unclip or unscrew the contact covering it. When the contact is off you will see the battery number written on battery - buy exactly the same one and replace. After replacement you will need to set the watch manually.
Jul 09, 2009 | Casio DW290 1V Classic Alarm Chronograph...
Timex Atlantis 100 screen went blank
same thing happened to mine. you might have cracked the inner screen and the only thing i can suggest is to replace it!
May 28, 2009 | Timex Atlantis 100 77511 Wrist Watch
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
I have a Timex 1440 sports watch. I have Parkinsons and must take medicine on a specific timed schedule. For a while all was well with this watch; the alarm rang when set. However, I think I inadvertently...
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
Dec 29, 2008 | Timex 1440 Nylon watch
Casio cmbi watch with didgital timer and normal clock on
I lost my instruction and need to set my watch to the correct time. It is a casio illuminater AW-80
Oct 26, 2008 | Casio AW80-7AV Wrist Watch
Adh1583
go to mode and scroll to select alarm setting.Look at the display of your watch if you see the icon of the bell there,it means its alarm hourly,if you off the alarm the bell icon of the display will gone,so it will not alarm..
hope this may help;
don't forget to rate;
Aug 10, 2008 | Adidas Candy Digital watch
Small 'eye' icon??
The "eye" icon appears when you have your backlight set to auto. that means when you move your wrist to look at your watch the light comes on automatically. I have found this to be a huge drain on the life of the battery. to turn it off hold down the light button (the grey button on the front with the red "g" on it) untill you hear it beep.
As for the watch dieing when the alarm goes off that is a good indication that you need a new battery.
Mar 08, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Gucci Ya114202 114 digital watch Logo
54 people viewed this question
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
