Question about BenQ MP610 Multimedia Projector
Change of lamp. How much will it cost? - BenQ MP610 Multimedia Projector
  • 442 Answers
You can change the lamp yourself so the cost is just what you have to pay if you get one on ebay
Posted on Apr 03, 2011
Got a 55 inch panosonic tv four years old no sound or picture, flashing light on front color red say's lamp please help
That TV uses different types of lamps to display the RGP spectrum. You may be able to find the replacement lamp on ebay but the cost to repair those types of TVs is generally not worth it.
Mar 01, 2011 | Panasonic Televison & Video
The lamp on my Canon MP600 scanner/copier has stoped working, I assume the lamp has blown. How do I change it?
It may be difficult obtaining a bulb, but you can remove the glass cover and remove the bulb. Go to a place where they service Canon copiers and see if they can get one for you. However it may not be cost effective, considering the cost of printers these days.
Feb 26, 2011 | Canon PIXMA MP600 all-In-One InkJet...
SCREEN IS BLANK ON SWITCHING ON - CAN JUST ABOUT SEE PASSWORD REQUEST AREA (VERY DIM)
There is a lamp behind the screen that lights the LCD panel up! Those florescent lamps are only good for 10,000 to 25,000 hours (depending on the model). One year of 24/7 is about 8000 hours. One girl I know left her's on 24/7 and her's died within two years and it cost her about $350 to have fixed.
Which is a waste, sinceif it is the bulb, they only cost like 25 bucks. But service centers usually change everything; the LCD, lamp, and the inverter. Anyway your LCD is just fine. It's either the lamp, inverter (circuit which generates about 800vac), or the wiring.
Supposedly you can't use an inverter with a different lamp or the other way around. So keep that
in mind.
Mar 11, 2010 | Dell Inspiron 1525 Notebook
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
Abs, brake lamp won't stay running
try to change the speed sensor and the differential sensor,good luck to change it cost of the parts is about 60 dollars both.
Aug 04, 2009 | 1999 Dodge Durango
Lamp
you need to make sure your fans, and vents are kept clean, if they cant cool the lamp properly, it will make the lamp go out faster, also change your setting in the menue to power save, or low power, saves on lamp time
Jan 08, 2009 | Mitsubishi WD-62825 62" Rear Projection...
How do you change out the lamp for a AKAI projector TV?
this is very common problem among rearprojection tvs. youll need a technician to come take out the lamp and replace it. its too dangerous to do it yourself. if ur tv just shutoff and didnt turn onn again the best thing to do is relpace the tv because its not worth replacing the lamp because its too costly and it might happen again. they dont really make these tvs no more so its pricy
Jan 13, 2008 | Akai PTH5498 54" Rear Projection...
How to change lamp on Hitach 60vg825
Yes, you are due for a lamp. Save yourself some money by ordering just the bulb p/n UX21516 (instead of the whole lamp assy), install it yourself. There are lots of us that sell these bulbs far below what the assy costs. Make sure it is an OSRAM bulb though.
Dec 31, 2007 | Hitachi 60VG825 60 in. LCD Television
BenQ MP610 Multimedia Projector Logo
21 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
