Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
I have a netgear wndr3400. I have 2 laptops, 1 can connect but the other can't. It says it is connected but to the wireless router but can't connect to the internet. Why can't it connect?
    Problem Solver:
  • 11 Answers
The router has probably provided too many IP address and assigned one out of your range.
  1. Click start button
  2. Type cmd, right click and run as administrator
  3. Type the words IPCONFIG /RELEASE
  4. Let it run until you are able to type again and type IPCONFIG /RENEW
  5. Then when it has renewed flush your DNS cache by typing IPCONFIG /FLUSHDNS
If that doesn't work, I would log into the router. www.routerologin.net and under settings release your IP address or cycle your modem and then your router.
Posted on Apr 03, 2011
Ive currently got the netgear DGN 1000 & ive currently got a HP notebook but the HP wireless network assistant does not list this modem so cannot connect, can you help?
Check the following and then try the solution:
1. Do you have other wireless devices connected?
Yes, go to solution #1, if you know the SSID then try solution #2
No, go to step 2.
2. Are there any wifi connection listed in range?
No, go to step 3
3. Go to a location were you know there is a wifi connection, can you see this connection in the wireless assistant?
No, go to solution #2
#1 my thought is you are not sure of what the SSID is, so place the laptop next to the Netgear router and chose the best wifi signal to connect to in wireless assistant.
#2 There is a switch/or button on the laptop to turn on the wireless. It is normally somewere on the side of the laptop, turn it on and it should glow blue. Now try to connect to your router.
Hope this helps
Jul 21, 2011 | NetGear DGN1000 Wireless Router
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
Lost of connectivity of my wireless connection of my laptop
Please check your laptop is getting wireless signal or not from your router.
If not then check your router is working fine or not with other device also.
Mar 31, 2010 | NetGear WGR614 Wireless Router
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
NETGEAR wgr614 cable wireless router
have you tried to follow the manual chapter 3, page 3-1 ?
If you lost your manual you can find one here:
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
One of your computers can go online because its using a wired connection to the router, but the wireless clients cannot access the connection - is this right?
Then you only need to setup the wireless part in the router.
Mar 07, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
684 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
