Question about Hyundai Q320 32 in. LCD Television
Hyundai 37 inch tv won't switch on
It was working fine when switched off
i have checked cables and fuse......ok
  • 4 more comments
  • Anonymous Nov 16, 2008
    I have the same problem with HLT-3210. Fuse is ok.
  • lizhowat Dec 29, 2008
    I have the same problem i switched television off at night and was not working the next morning, the red stand by light was on pressed power on the remote, the green LED light came on power came through the t.v but was no picture.
  • lokoso90 Mar 22, 2009
    the same problem,hyundai 37 inch tv won"t switch on,give sign to show then off.
  • Kyotowolf Mar 23, 2009
    I have the smae problem as well. It was working fine in the evening then I swtiched it off. Then in the morning I turned it on adn green light went ton but no picture or sound was prodcued.
  • monkeyqueen May 10, 2009
    I have the same problem and can't find a contact number for Hyundai - does anyone have an e-mail / phone number for them?
  • Anonymous Oct 30, 2009
    I have the same problem. Just ordered a repair kit £4.95. Will give an update on how it goes.
    http://www.ohmsupplies.co.uk/epages/6202...
    New Friend:
Kit has fixed the problem.
Posted on Nov 04, 2009
    New Friend:
Hi Stu
Is the kit easy to fit ?
Posted on Dec 13, 2009
I had the same problem. Call them immediately and have them ship a replacement. It is a known fault. I have had to have 2 replaced for this.
Posted on Nov 07, 2008
SOURCE:
Why don't low beams work?
As well as fuses there are relays in the under hood fuse box. They are square and about an inch and a half high. Make sure they are seated OK.
Right hand side in the image
https://motogurumag.com/i/hyundai-elantra-fuse-box-diagram-XfeNxpu.gif
Dec 28, 2015 | 2001 Hyundai Elantra
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Hello, My Hyundai will not start, i think it might be the starter, but the battery is good and all the lights work and everything, but when I go to start it, I have nothing. I won't crank, click,...
check on the fuse box, am sure that a starter fuse is blown. the alternator might be the causer. as you said you changed it not so long. When you find out the fuse are ok, check also the solnoid wire on the starter motor beside the main wire, when that is good then might be the carbon brushes are won need to be replaced
Aug 24, 2011 | 1999 Hyundai Accent
Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Sep 09, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV switching to standby
Hi.i had exactly the same problem with my bush 37 inch lcd tv and i took it to a friend of mine who is a t.v electrician he said it was a component in the back of the tv which he replaced and its now working fine.
Jul 05, 2009 | Televison & Video
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Hdmi
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Feb 02, 2008 | Philips HTS-6500/37 System
Toshiba 37 inch tube tv wont turn on
Any set that won;t turn on is probably due to a power supply converter which has burned out switching semiconducors. The first thing to do with a set which will not turn on is to check out all the switching gear (ie switchmode converter circuits) and all associated drive and driver semiconductor devices. Once you've done this you will usually find the problem.
Dec 13, 2007 | Toshiba 32AF43 32" TV
PHILIPS TV 32PT6441/37 SHUT DOWN
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Philips 32PT6441/37 32" TV
Hyundai Q320 32 in. LCD Television Logo
913 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Eric Rotmil
Eric Rotmil
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
