Question about Toshiba Computers & Internet
I am asking about my laptop problem when i turn the power on. after 10 secs.my laptop turn off without showing anything on lcd screeen..hoping for your response ..thanks a lot
  • 28 Answers
It sounds like you are having a heat problem. Check the vents on the side and it is blowing air if not the fan might not be working, If it is under warranty call were you got it and they will help you.
Posted on Apr 03, 2011
My computer broke down I can't see anything the whole screen is black
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Or, if you are hearing the welcome sound, but no display, that could be a LCD problem.
Mar 20, 2011 | Computers & Internet
A white screen display on my laptop
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center or contact ASUS (if in warranty) to have it check for LCD problem.
Mar 16, 2011 | ASUS LCD Monitor
I have a white screen display on my laptop. an asus laptop. tnx
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for LCD issue.
Mar 16, 2011 | ASUS Computers & Internet
The display is blank the printer can off and on but nothing comes on the display
Good day!
POWER CYCLE
You may also try connecting an external monitor to check if the display will show. If it does, the problem is the LCD of your laptop and you need to take it to the nearest repair center.
Mar 13, 2011 | Computers & Internet
NOTE BOOK SCREEN DOES NOT COME ON
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Mar 12, 2011 | Acer Aspire One PC Notebook
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Acer 4810 tz is like dead. I cant turn it on anymore, neither with battery (charged) nor without.. Please help! Antonio
There is an easy fix solution that works most times when your PC/Laptop suddenly does not turn on. Dont ask why or how but follow it.
1. Disconnect all the power supply, that is remove the adapter cable and remove the battery.
2. Press and Hold the power button for 10 to 20 Seconds(very important 10 secs at least)
3. Put back the battery and connect the power adapter and try switching on your laptop.
Aug 01, 2010 | Acer Aspire 3610 Notebook
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
Computers & Internet Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
