Question about Cosco Juvenile 22209WAL Booster Car Seat
I needed to wash the seat cover and need help putting the straps back on
  • 396 Answers
It looks like there are two different manuals. A 2006 or a 2008. The 2006 is available but the 2008 is a bad file at Dorel, Oh Well! Try the 2006 manual.
You can do it easily by using the link below and putting in your model number and date of manufacture.It will pull up a manual and you can save it to your computer for future reference.
Here are links to the 2006 and to the lookup site at the bottom. Good luck.
2006 Model Manual Link
Cosco Car Seat Manual Lookup
Posted on Apr 03, 2011
SOURCE: I need to put the cover back on the baby's car seat and can't remember how! Help!
You've probably already figured this one out - but for any of you having trouble getting everything back together, might i suggest www.djgusa.com
YOu can search for the manual ONLINE to YOUR particular model number (right on the side of the car seat) - I have a car seat from a friend, so i didn't have a manual to consult - until NOW!
Posted on Jan 07, 2008
SOURCE: Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Posted on Sep 27, 2008
  • 43 Answers
SOURCE: Putting the car seat back together
if you have the model number and manufactor date you can go here and get a free manuel http://www.evenflo.com/support.aspx?id=256 hope it helps and if it does please leave me a good rating
Posted on Nov 18, 2008
  • 20 Answers
SOURCE: Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
Posted on May 08, 2009
SOURCE: harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Posted on Sep 09, 2009
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
May 08, 2009 | Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
Mar 08, 2009 | Century Encore 5-point Harness
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax eclipse
Try Britax.co.uk, they have all the user guides and instructions available for free download. i had the same problem as i washed the seat covers and then couldn't remember how to put the harness back. Hope that Helps.
Jul 16, 2008 | Britax Eclipse Si - Paris Convertible Car...
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Need instuctions
washed the cover , now i am trying to put it back together.
Feb 24, 2008 | Cosco Alpha Omega Elite - Hammer Print
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Cosco Juvenile 22209WAL Booster Car Seat Logo
907 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
