Question about Sony DRU 510A DVD±RW Burner
Sony DRU510A DVD Writer - I can burn CD's, I can watch DVD's, but when I try to burn a DVD it won't recognise the blank DVD. I am using DVD-RW. I use RecordNow DX. I am a novice user. Thanks very much.
  • Sony Master
  • 27,725 Answers
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 03, 2011
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
I have a HT-DT-ST- RW/DVD GCC 4480B it will burn cd-r but it wont even read dvd-r I just want to burn dvd-r but it wont even read blank one
> CD-RW / DVD-ROM
Sorry, but this device is not a DVD-writer.
This device _should_ read (non-blank) DVD media.
If it does not, then the cheapest solution is to spend $40
to buy a new CD/DVD reader/writer.
Oct 26, 2010 | LG GCC 4480B CD-RW/DVD-ROM Burner
DVD not burn by the Writer but burns CD easily.
Some steps you can try.
1. Try a different brand of disks.
2. Try a different burning program.
3. Clean the lens.
Hope this helps you.
Regards Bill
Jun 30, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
Can't write dvds
i have same problem. i tried to fix it myself but didnt work its the problem of dvd-writer no problem with software, i know becoz i took my friend's dvd-writer and its woking absolute fine, so better take it to some hardware repair shop.
Oct 02, 2009 | Computers & Internet
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Sh-s202 dvd writer recognises DVDs to play, but not to burn onto.
Try using a quality dvd lens cleaner. Run it a cycle or two of cleaning then retry the dvd. If it works it was just a dirty laser. If this doesn't correct the problem then it might be a dvd optics issue. Hope this helps.
Mar 17, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
MY CRX320EE DOESN'T BURN DVD'S
This is because the model you mentioned is just a combo drive. It is not a dvd burner. You can watch dvd's with it but not burn them. The way manufacturers word the advertising leads some people to believe that they have a dvd and cd burner. All you have is a cd burner / dvd player. What you want is a dvd-rw / cd-rw drive. Sorry! I hope this helps.
Dec 05, 2007 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
The above internal burner not picking up blanck dvd-r
strictly speaking this is the correct response from your writer, as the disk "is" blank. Your DVD burning software, Like cloneDVD or Nero, should recognise the "blank" and then allow you to burn your disk image. you need to check that your DVD/CD authoring software is installed correctly and updated for all the latest features.
Aug 09, 2007 | ASUS DRW 0402P DVD-RW Burner
Open Questions:
Sony DRU 510A DVD±RW Burner Logo
120 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
