Question about Epson TM-U220 Matrix Printer
"Generic / Text Only" driver printer and cyrillic
I am using an application that only supports printing with the "Generic / Text Only" driver. I recently purchased a TM-U220 receipt printer and have it configured as "Generic / Text Only" driver printer. My question is that I need to be able to print Cyrillic(Russian) characters and this configuration is not able to print the cyrillic text. Do you have any ideas for printing cyrillic text when configured with a "Generic / Text Only" driver?
  • Anonymous Mar 23, 2014
    i want to print ZPL cod on usb zebra printer S4M 300 dpi configured as Generic / Text only on windows 7 usinf USB port
    New Friend:
I had the same issue with a Brother QL-500 using the P-Touch software. I've also had the issue with several other non-english characters. I found no answers on how to manage it, but did come up with this solution.
Copy and paste the text into an editor that can read it properly (MS-Word etc..). Format the text/address so it appears how you want it. Make it 'bold' then zoom in to max size to make it fit the whole screen. Press <PrintScreen> and then paste the image onto the label. There is a facility to 'crop' the image and get rid of all the extra bits around the text/address. Then stretch it to fit properly. Hope this helps.
Posted on Jul 10, 2013
  • Epson Master
  • 1,879 Answers
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Posted on Feb 26, 2009
My printer prints very small laters
>what applications or documents are you printing?
>this could be application specific or the printer driver is incompatible with the application. you can check by printing other application or documents.
>you can also install generic driver, go to printer and faxes folder add a printer, add a local printer and select usb port, select hp as manufacturer and select deskjet 990c as your print driver
>you can also try to go to www.hp.com select support and drivers and then download the latest driver for this printer and install it
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
Jun 25, 2009 | Tally T2250 Matrix Printer
Html to generic text
rename the file extension as .htm and then open the file in a browser. then go for printing... you will get text and not html codes..
Sep 04, 2008 | Epson ActionPrinter 5000+ Matrix
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Got virus, got rid of virus, cant print, not recognizing printer, uninstalled and reinstalled but wont finish saying "The specified print monitor is unknown"
Need to know more about the printer make and model to diagnose this completely. But the first step is to take the third party applications and software issues out of the equation.
For PCL printers setup and print to the printer using the "generic-text only" driver in Windows. For any PS laser printer, you can usually use the laserjet4 PS driver. If attached USB, unhook and plug the printer into a different port first.
If you still can't print, the print monitor in Windows was probably corrupted and you will have to run a repair using your original system disk. This happens often with virus which replace system files in order to hide from AV scanners.
If can print, then you (1) probably have an injet and (2) probably have a failed uninstall of the print applications. Third party print applications still running as a service can cause this same issue.
Jul 23, 2008 | Lexmark Office Equipment & Supplies
Generic / Text Only (To File) printer driver cutting off at 85 columns wide
I found a solution to my problem above. In the Generic / Text Only driver I chose a page setup of "ledger" (as opposed to letter, legal, etc.) and that produced the correct output with all of the columns.
Apr 18, 2008 | Office Equipment & Supplies
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Epson TM-U220 Matrix Printer Logo
3,003 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
