Question about Sentry Fireproof Safe
Safe will not open display reads "proceed" - Sentry Fireproof Safe
    President:
  • 1,654 Answers
Opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
These are the instructions from sentry on this. If the safe will not open after following the instructions, they require you to contact their customer service. If this is new and not been used then you should take it back where you purchased it and let them know of the issue. You can try and force the door inward while pulling the handle, sometimes the locking bars get tight in their slots and makes it difficult to open. You may need a locksmith to help with this if the door still won't open.There are either 4 AA batteries or in some cases one 9 volt battery that has to be replaced .. in some models you slide off the area under the keypad to get at the battery .. .. as the battery ages it has enough current to operate the display but not enough to operate the unlocking mechinism .. once you have it open make sure the mechinism works freely even lubricate itbut don't use a gummy type of oil, use something light like sewing machine oil.
Posted on Apr 03, 2011
  • Dcramer531
    Dcramer531 Apr 03, 2011
    The other things that sentry recommend is to puch up or down on the hanled while entering code in case a piece of paper or such gets caught in the mechanism. They also recommend tapping 5 times on top of the panel and 5 times on sides with a rubber mallet to free up the mechanism if it is not moving. My guess it is the battery under the panel!
    Good luck on this!
I have a Sentry A3810. After putting the ecode in and the "Proceed"light comes on,
We believe there is no solution to your problem as lack of opening lock on a periodic basis leads to moisture build up rusting the lock shut. If your model is still under warranty it ca be replaced. Call A1 Locksmith for additional info on drilling it open.
Jan 28, 2013 | Sentry Fireproof Safe
How to unlock LG HT303SU-A2 multiregion code?
Yes they are both completely different models of the same brand.
Dec 07, 2012 | LG HT303SU Theater System
No help from Sears!
door indicator is the microwaves way of telling you the door isnt closed. does it run at all if it doesnt its probably a door switch. theyre there as a fail safe because your microwave shouldnt run with the door open
Jul 24, 2012 | Kenmore 62702 Microwave Oven
Nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
Hi. I have a Godrej make e-swipe safe (locker). It has been functioning alright. But recently even after correctly giving the 4 digit password, the display says 'OPEN' and after 3 secs 4or5 beeps given...
i have a godrej locker at home , but i locked it twice and now the message comes secure . now how do i open it. the code is same but it was locked twice and so the message came as secure - good.
now i can't open it
Feb 01, 2011 | Safe International Digital Electronic Safe...
1998 Nissan maxima ABS light is on
0) url = inUrl tWindow = window.open(url, '_notes', 'toolbar=no,location=no,status=no,menubar=no, scrollbars=yes,resizable=yes,width=650,height=400') setTimeout('toolbarFocus()',500) } // --> ence blnk_spc.gif g_angle.gif blnk_spc.gif blnk_spc.gif "); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } function SizedForPrint(ImgName, ZoomPct, W, H, Target, Title, ImgMap, MapVar) { msg=window.open("",Target, "toolbar=yes,directories=no,scrollbars=yes,status=no,resizable=yes,menu=no"); msg.document.writeln(""); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } function SplitImagePiece(ImgName, ZoomPct, W, H, Target, Title, ImgMap, MapVar) { W = Math.floor(W * ZoomPct); H = Math.floor(H * ZoomPct); msg=window.open("",Target, "toolbar=yes,directories=no,scrollbars=yes,status=yes,resizable=yes,menubar=yes,location=yes"); msg.document.writeln(""); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } // --> blnk_spc.gif
  1. Connect diagnostic read-out tool to SMEC connector, then disconnect the speed sensor connector and ensure there are no pushed out or damaged terminals. Repair damaged terminals, then proceed to Test 38.
  2. If there are no damaged terminals, set diagnostic read-out tool to ``Read Sensor Values,'' and select ``Vehicle Speed.'' Connect a jumper wire at between black/light blue and white/orange wires of speed sensor connector. While reading diagnostic read-out tool, make and break jumper wire. If display reads any speed above 0 mph, replace speed sensor, then proceed to Test 38.
  3. If display reads 0 mph, turn ignition switch Off and disconnect 60-way connector from SMEC. Ensure there are no pushed out or damaged terminals. Repair damaged terminals, then proceed to Test 38. If there are no damaged terminals, proceed to step 4.
  4. With sensor disconnected, connect ohmmeter between 60-way connector terminal No. 67 and ground. If ohmmeter shows continuity, proceed to step 6. If ohmmeter does not show continuity, move meter lead from ground to white/orange wire of speed sensor connector.
  5. If ohmmeter indicates continuity, proceed to step 7. If ohmmeter does not indicate continuity, repair white/orange wire of 60-way connector for open circuit, then proceed to Test 38.
  6. Disconnect bulk head connector to instrument panel. If ohmmeter still indicates continuity, repair white/orange wire for a short to ground in harness, then proceed to Test 38. If ohmmeter does not indicate continuity, repair white/orange wire for a short to ground in instrument cluster area.
  7. Disconnect ohmmeter leads and connect ohmmeter between 60-way connector terminal No. 4 and sensor connector black/light blue wire. If ohmmeter does not indicate continuity, proceed to step 8. If ohmmeter indicates continuity, replace SMEC, then proceed to Test 38.
  8. If ohmmeter did not indicate continuity, repair black/light blue wire of speed sensor harness for an open circuit, then proceed to Test 38.
blnk_spc.gif _uacct = "UA-1870158-7"; urchinTracker();
Sep 24, 2009 | 2002 Nissan Maxima
Admin account on Vista pc locked out, forgot admin password
Step 1
START THE COMPUTER. DO THIS BY PRESSING THE POWER BUTTON. DO NOT WAIT UNTIL WINDOW LOADS TO PERFORM STEP 2.
Step 2
PRESS F8 KEY ***BEFORE*** WINDOWS VISTAmag-glass_10x10.gif BEGINS START UP. THIS WILL PROVIDE A LIST OF OPTIONS FOR HOW TO PROCEED.
Step 3
CHOOSE TO START YOUR COMPUTER IN "SAFE MODE".
Step 4
OPEN THE START MENU.
Step 5
OPEN THE CONTROL PANEL (from within the Start Menu).
Step 6
SELECT "USER ACCOUNTS AND FAMILY SAFETY" IN THE CONTROL PANEL POP-UP WINDOW.
Step 7
CLICK THE "CHANGE YOUR WINDOWS PASSWORD" LINK BENEATH THE "USER ACCOUNTS" SECTION.
Step 8
CLICK "REMOVE PASSWORD". VERIFY AND SUBMIT.
Step 9
RESTART YOUR COMPUTER NORMALLY. DO NOT PRESS F8.
Step 10
TO RESET A PASSWORD, ACCESS THE "USER ACCOUNTS AND FAMILY SAFETY" MENU AGAIN. THIS TIME CLICK "CHANGE YOUR WINDOWS PASSWORD", PROVIDE THE DESIRED PASSWORD, VERIFY AND SUBMIT. THIS TIME, WRITE YOUR PASSWORD DOWN.
If this helps please rate me. thanks
May 09, 2009 | E-Machines eMachines W2686 PC Desktop
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
90 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
