Question about Onkyo HT-S780 System
Onkyo ht-s780 I turn the base up past min the system shuts off
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 03, 2011
MANUAL GUIDE OWNER ONKYO RECEIVER AV HT-R530
Hi Javier, you can located the owners manual at the following link, http://www.onkyousa.com/Downloads/manuals.php?source=globalnav. Note that your unit is part of the HTIB HT-S780, Thanks, JT
Aug 24, 2015 | Onkyo Audio Players & Recorders
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
Inquiring about a new remote control for home theater system.
The Harmony universal remote is on clearance at my local Radio shack for $37. Normally $100. Great remote.
Jun 26, 2009 | Audio Players & Recorders
ONKYO HT-S780 B SPEAKERS
Your symptom sounds as though you may have to turn off any surround sound settings that you have selected in the other modes.
Most amplifiers use the surround portion of the amplifier to power the B channel speakers.
Since you have sound when using the radio portion, I would try turning off the surround mode. For example try turning the amplifier to just stereo and see if that gets the B channel speakers to work
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 22, 2009 | Onkyo HT-S780 System
Remote code needed for onkyo
First try: 32905. If that doesn't work maybe try the following: 30490, 30573, 30744, 30820, 30899, 31044, 31075.
Jan 29, 2009 | Onkyo HT-S780 System
Using An Onkyo Remote to control Sky+
Code that I have for sky + is: 01175. There are several other codes for other versions of sky boxes if you think you may need them but that should be the one.
Samsung has a huge code list: 10017, 10037, 10047, 10054, 10056, 10060, 10090, 10092, 10093, 10154, 10156, 10178, 10226, 10702, 10766, 10814, 11060, 11235. Unfortunatly you'll just have to try them one at a time until you find one that works. Hope this helps.
Jan 07, 2009 | Onkyo HT-S780 System
3 speakers dont work
Check to make sure that Speaker B is not pushed. It's on the front panel on the bottom left.
Dec 14, 2008 | Onkyo HT-S780 System
Setting up cable box/ hdtv/ blue ray dvd/ through an av system.
If you are using just component cables it's as simple as plugging them into the appropriate ports on the back. One nice feature of the HT-S780 system is the multiple digital audio ports and the ability to map them as you like.
Nov 29, 2008 | Onkyo HT-S780 System
Remote control codes
Here is a link for the complete manual :
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
remote codes start page 61
To control an Onkyo receiver with a universal remote try code 0135
Hope this helps
Alex
www.CustomAutomaticSystems.com
Nov 11, 2007 | Onkyo HT-S780 System
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
65 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
