Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Cranks and runs good but has no power - Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
Why doesn't it crank or start?
Check battery connections and voltage. fuel pump only runs for a few seconds to start and runs again while cranking.
Mar 10, 2016 | 2004 Chrysler Sebring Convertible
99 suzuki vitara v6 turns on all power but wont
the starter uses 10x more elect. power than the head lamps
or 100x more than dash lamps. it means little.
what matters most is jumper cable starts.
does it crank with jumper cables to a running, donor car,(aaa jump)
no bad starter
no, bad starter key line( immobliizer or such) ask how to test.
yes, cranks great, now.
that means the battery was dead,
i charge the battery and it now cranks, due to lights left on or
charge system failure, if battery goes to 13.3 to 15v running good
if on the charge system failed. (causing battery discharge)
if after charging a battery it will not crank car, its a bad battery (jumps ok)
Sep 09, 2014 | 1999 Suzuki Vitara
No power going to ignition control module, what would cause this?
Yes, the pink wire to the ICM and from the run/crank relay should have battery voltage in run or start. If not, check fuse 11, a 10 amp fuse in the Fuse Block-Underhood. Also check fuses 38- a 30 amp fuse supplying power to the run/crank relay, and fuse 9- a 10 amp fuse between the run/crank relay and the ECM. All of these fuses are in the underhood fuse block.
Fuse 38-the 30 amp fuse, the power feed for the run/crank relay- will be hot at all times. Fuses 9 and 11 will be hot in run or start. Check for power at the fuses. If the relay is not turning on and sending power to those fuses and to the ICM, and the ECM, (and to the injectors through fuse 16 - a 10 amp fuse), then work back to the ignition switch and the body control module. Wish I didn't have to say that, but yes, the BCM is between the ignition switch and the run/crank relay.
Good luck, Michael.
May 27, 2014 | 2003 Saturn ION
2002 heritage with fuel injection every thing works but no power coming from fuel pump fuse and fuse is good?
First off testing for power at the pump can be tricky, The pump will only get power for a few seconds when you turn the key to the on position. This is the Fuel prime function. It will also stay powered when the engine is cranking or running. If the car doesnt run, you will either need to have a helper cycle the key (waiting 10 to 15 seconds between key off then on) or have them crank the engine over (for no more than 15 seconds at a time) to see if the pump is being powered, If the pump Still has no power during either of these, there is a wire between the fuse and the pump that needs to be repaired. You will have to physicaly examine the whole wire from fuse box back, If the fuel pump has power during the prime function but during cranking, I would suspect that it is the crank sensor, as this is the primary input to command the fuel pump to continue to run.
Apr 05, 2014 | Cars & Trucks
98 jeep cherokee loses power for no reason and only cranks when it wants to
your crankshaft position sensor located on the left side of the upper transmission and good luck.
Dec 12, 2012 | 1998 Jeep Cherokee
My 99 Gmc jimmy will not start. the fuel pump is good the fuel filter is not clogged, i replaced the neutral safety switch, plugged in my code reader no codes, i believe it is the starter or the ignition...
Does it crank or not? If no crank then look at the starter or ignition switch. If crank but no start then look at the ignition system. Check for spark at the plugs and also check the fuel pressure. If there is spark try spraying a little starting fluid into the intake. See if it starts and stays running. If it stays running reply back and I will explain why.
Sep 02, 2011 | 1999 GMC Jimmy
Car cranks then an hour later won't crank
Battery or starter. Sometimes the battery will have enough power to activate fuel pump and dash lights but not enough to turn starter.
Sep 23, 2009 | 1996 Honda Accord
Fluid leaked on belt; car won't fully crank;how do i get to run?
check you crank sensor wiring. wires run from behind a plastic cover up and out towards the radiator. good luck
May 25, 2009 | 1991 Buick LeSabre
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
32 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
