Hi,i m trying to connect the sub jbl 4006 sub 12 to my tx-sr 607
  • 62 Answers
You the right jacks to that that can help you !
Posted on Apr 03, 2011
How do I connect jbl psw1200 sub?
Well, it depends what you're connecting it to....
If it's a stereo receiver or Hi-Fi amp, then the speaker cables that would normally go direct to the front L & R speakers now connect to the sub's L&R speaker OUT sockets. Then you need two extra lengths of speaker cable. These go from the receiver's speaker outs to the sub's L&R speaker IN sockets.
Connecting to a surround receiver, just use the phono/RCA cable from the receiver's "Sub Pre Out" to the white phono/RCA labeled Low Level IN.
Aug 30, 2014 | JBL Audio Players & Recorders
Can you install two powered subwoofers to an onyko tx-sr 608 receiver 7.1
get an rca y-splitter for the sub out, and you can run a signal to 2 subs
Mar 23, 2013 | Onkyo TX-SR608 Receiver
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
Hi ,how can i connect my two 10 inch JBL double voice 4 ohms coils to my jbl gto 7001 amp
It is confusing with the 4 channels it gives you but you really only need to connect it to one or the other positive and negative terminals. The amps channel setup looks like this + - + - . You can connect to the first positive and negative, the second, or combine them. I had mine installed by a professional which is how I know. Also if you want to run your amp at 2 ohms then connect the subs voice coils in a parallel circuit which means that all positives are connected to each other and the same goes for the negatives. it should match the impedances of both sub and amp. Hope this helps!
Apr 13, 2011 | JBL GTO7001 Car Amp
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Hi need some help instaling audio system on my bmw e39 525tds,got fuel shockwave 800 watt 3 oms subwoofer,2 JBL gto936e speakers and 2 sony tweeters and toxic tx-600 amp,can you tell me what wiring i need...
Walmart or a Specialty Audio Shop would carry a basic wiring kit for your job at task. As for the additional amp, thats your personal preference. If the Toxic Tx-600 AMP is a 600w amp, then I would say that is decent unless you're looking to get tickets for sound violations.. if you live in a city.
Jul 26, 2010 | JBL GTO936 Coaxial Car Speaker
How to get two M-282's to power one non-powered sub
you can't get 2 amps to drive 1 sub since your amp is not designed to be able to run in mono or bridge mode.
However, what you can try is to reverse the + and - terminal.
The reason is that if the sub is place at a location where the wave cancels out the wave, it'll actually make the entire base go lower.
So sometimes reversing the polarity will have the enhanced effect.
Give that a try.
Also, you may want to consider using the main out rather than the subwoofer out as the sub out may have a filter build in that may actually get in the way of the signal.
Jul 23, 2010 | Onkyo M-282 2-Channel Amplifier
Have an onkyo txsr501 w/jbl scs135 surround sound sys, i disconnected it to paint room and when I hooked it back up the sub worked for about 15 mins than stopped went to standby, if i turn off the sub and...
If there is a way to cut and resplice the speaker wires at both the receiver and the speaker connections, try that. A good clean cut with no hanging copper wires is key.
Nov 25, 2009 | Onkyo TX-SR501 Receiver
Onkyo SR-803 UNPOWERED Subwoofer conectio0n
HI,run speaker cables from "b" speakers out put to speaker in puts on the sub and switch "b" speakers on on the amp.
hope this helps.
CABLE GUY.
Jul 28, 2008 | Onkyo TX-SR803 Receiver
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
67 people viewed this question
 Grubhead
Grubhead
