Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Barracuda climbing walls almost to be out of the pool. Sometimes I think it is high enough to **** air.
    Problem Solver:
  • 20 Answers
There are several adapters on the market to allow more water to bypass the cleaner. One is called the Vac-Mate, another is the Hayward skimmer adapter. I personally like the vac-mate. but it's only compatible with most skimmers.
Posted on Apr 04, 2011
My Gw9500 won't climb all walls in my pool
get one of your kids to do it by hand. Those things never do anything except destroy your pool and income.
Jun 10, 2014 | Pentair Kreepy Krauly Great White GW9500
The dolphin maytronics does not climb the wall
Thank you for posting your question here on Fixya.com.
Several possibilities to consider...
How old is the filter bag and is it clean?
Older bags or bags not thoroughly cleaned can resist water passing thru them to the point there is not enough downward pressure to allow the unit to 'bite' the pool surface and climb.
How worn are the brushes and tracks?
Worn brushes and tracks will slip once worn enough. Replacing them could fix the problem.
Is it trying to climb or does the unit start up the wall and immediately reverse?
If your motor has been replaced new style motors spend far less time climbing assuming most debris will instead be found on the pool floor. If it has not been recently replaced the program within the motor may be failing.
What is the condition of the pool?
Low water temperatures and/or algae can cause the unit to slip in place and as a result it will not climb. Eventually it will scrub enough to gain traction and will slowly progress up the wall. For temperatures below 70 degrees the unit will find in more and more difficult to climb the lower the temperature.
What material is the pool surface?
Some linered pools and fiberglass pools require climbing rings in the brushes. Do you have those? If so, what condition are they in? Worn rings or missing rings will prevent climbing those and other smooth pool finishes.
For more troubleshooting tips try our site at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. You can also check the manufacturer's site at www.maytronicsus.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Dec 31, 2010 | Dolphin Maytronics Diagnostic Robot...
Wont climb wall
Nov 23, 2010 | Dolphin Maytronics Advantage
Cleaner does not climb walls
First of all do you have enough suction? The cleaner originally should have come with a suction gauge. If not the local pool store will have one. How old is your cleaner? When the G3 and G4 cleaners gets over a year or two a number of things wear out and effect the performance. Inspect the diaphragm especially next to and under the small retaining ring and make sure there are no holes or tears. If the diaphragm is over a year old they sometimes get too spongy and effect performance. Also the small rubber pad that holds the large pad can get worn down and stick to the floor and wall. As parts wear down you can get play or slop between the large disc, the small pad, and the foot plate that snaps all the disc to the body. Also the rear cassette where the hose connects gets slop there as well. all of this slop, especially when combined can make the cleaner performance lack greatly. very common to have a cleaner not climb the walls or reach the far end of pool as it once did
Sep 12, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
It stops after 30 min. Lays on it's back then starts up again. Has trouble climbing the walls to the very top
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure that there is no water in the handle and that the bushes arent worn. If the cleaner is too light, add weights. Make sure there is nothing caught in the impeller.
Jun 25, 2010 | Smart Pool Inc Dolphin Diagnostic...
The barracuda just returns to the deep end of the pool and stays there, how can I get the cuda to sweep the whole pool?
The Barracuda Zippy is an Above Ground pool cleaner and is not designed for a pool that does not have a flat bottom. They are generally not capable of climbing slopes, walls, etc.
Apr 19, 2010 | Zodiac Baracuda Zippy Pool Cleaner
My turbo bot does climb the walls of my pool. I have had it checked out with service. they could not find any problems. Any suggestions?
Not too uncommon. The float design is such that many units lack enough bouyancy to work well on wall climbing. New floats or added floats may help. S. Christian dansker01@msn.com
Jun 25, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Dolphin will not climb up walls.
What is you pool surface? It may need climbing rings to assist it on 'slick' surfaces like fiberglass.
Try moving the location of where you set the power supply from use to use to allow it's cleaning patterns to shift around for better coverage.
Jun 07, 2009 | Smart Pool Inc Dolphin Diagnostic...
Tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
May 26, 2009 | Aqua Vac Tiger Shark
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
183 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
