Question about Dometic RGE400 Top Freezer Refrigerator
Dometic Top Freezer RV/TT Refrigerator
My tt/rv refrigerator is a non-defrost type. Lately, I have had to defrost the freezer section but not the refrigerator and water is dripping down from the top of the frige. What is going on and can it be fixed?
Thanks,
ltd
  • 3fishnet Aug 16, 2008
    I have not received a reply concering this problem. Please respond.
  • 51 Answers
You have a switch inside the door. Turn it on this actually keeps the light on inside. This may help with your humidity problem. Also check to make sure the drain out side of the coach is not clogged you should see water coming out
Posted on Sep 07, 2008
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
My rv refegerator freeezes as if it was the freezer as low as twenty degrees any help would be appricatedThanks Brian
sounds like you need a new thermostat. refrigerator section should be between 34-40 degrees. is the temperature in the freezer ok? what setting do u have the thermostat set at?
Feb 04, 2011 | Dometic RM2652 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
My Dometic rv Refrigerator does not cool the lower (fridge section) properly. The freezer section is fine but the cold doesn't seem to be getting to the lower section. Adjusting the slide on the rear vanes...
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
Jun 30, 2010 | Refrigerators
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Refrigerators Logo
137 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
