Heve a phillips 60pp9202 projection. i had convergence issues being that i couldnt move my red. i went in and replaced both ics but i forgot to check the resistors. a week later i finally got in there and found 2 bad resistors. the thing is i didnt take the convergence board out, nor did i unplug anything when i tested the resistors. i put the cover back on until i get the parts. now, for some reason, when i power up the set it will come on like normal, then you hear a click and the screen will go black, with no audio. then the power button will flash red 9 times repeatedly and will not come back on. the only way it will come on is if you unplug the tv for about a minute, then plug it in and turn it on. Then it will do the same thing. can you please point me in the right direction. Thanks Mark
  • 3,459 Answers
Get a complete kit from www.TvRepairKits.com and start over.They will walk you though the repair.
Posted on Apr 15, 2011
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
I phillips 60pp9202 red went out of focus so i replaced two Stk 392-120 with Stk 392-180 and two resistors, but now i have a bow effect please help
check resistors on convergence board for open ,check wiring and make sure cables were placed in right place then perform auto convergence
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Manual Convergence
your convergence ICs have failed. You can get the convergence repair kit for your model at the following link which contains both convergence ICs and all of the feed resistors, plus the kit contains step by step instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
