Question about Taylor 632-27 Ice Cream Maker
Machine runs and mixes. Compressor seems to run but mix will not thicken. Seems like mix is not getting cold enough. A water cooled unit.. Tried to bypass water intake switch so water was always running through but still didn't work. any ideas thanks
  • 30 Answers
If its a water cooled unit when the compressor is running water should be running thru the valve, if it isn't be sure you have the water correctly hooked up and its cold water, if it is and still no water you have a bad valve
Posted on Sep 05, 2011
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Hello I have a 8754 Taylor and having trouble with the (chocolate)left side of the machine.The product goes soft after I've served about fifty cones. this is what I've tried *installed all new o rings...
sounds like a freon like to me if the compressor is running for long periods and not freezing properly or you have a water pressure issue. if it is water cooled which alot are it is hard to realize you have a freon leak.
Dec 12, 2014 | Taylor Ice Cream Makers
I need instruction manual for prolectric ice cream maker 1 ltr
fill cylinder with ice cream mix, layer ice and salt in the outer section and plug it in. Keep the ice/salt coming until mix freezes and thickens. You will know this is happening by the sound of the motor and when the unit stops turning it is done. Enjoy some for me.
Aug 25, 2013 | Ice Cream Makers
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Hi, I hav bought an ICE-50BC ice cream maker. It is now 3 weeks old & has been used 3 times. When the ice cream begins to freeze the stirrer arm always lifts off the machine & stops working. when I...
    See the BOLD section below..
    You need a good simple recipe. So here is one.
    (This is an unpasteurized recipe unless you boil the blended strawberries, wash the berries very well if you don't)
    1 lb fresh strawberries (ripe is better)
    3/4 cup sugar (most folks double this but i prefer the taste of strawberry)
    3/4 cup whipping creme
    2 1/4 cups milk (2%)
    1 tsp lemon juice
    Liquefy the strawberries in your blender. (Boil now if pasteurizing) and add the rest of the ingredients and blend.
    You now have enough Ice cream mix for two partial batches. Divide mix in two equal portions. You should have enough to fill machines bucket 1/2 - 2/3 full.
    IMPORTANT
    Do NOT have more or less in the bucket as the machine screws up with more or less of any mix.
    Insert Paddle and put noisy grey power arm on top.
    Add a 2 inch thick hardcover novel on top of arm above bucket.
    Add a heavy Soup can on top of this book (I recommend Habitant French Canadian Pea Soup 28 fl oz size).
    Set timer to 40 minutes.
    Leave room as it is a noisy little beast machine.
    Come back and check just before it is done. If still too liquid add 5 minutes to timer.
    Empty into bowl and add 2nd half of mix to bucket.
    Clean the dimple on bottom of mixer paddle before putting back in bucket. This batch should take 5 minutes less as compressor is already cold.
    Have fun.
    The book and Soup can are essential to keep the silly beasts power arm from lifting up too early.
    Apr 28, 2011 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
    I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
    It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
    Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
    The motor runs but it will not turn the dasher.
    dasher is supposed to be statioary so it can scrape off the frozen mix as the cannister turns. That is the secret to mixing the frozen mix into the unfrozen part to thicken the mix in the can. It pushes the frozen part toward the middle as it scrapes it.
    Mar 21, 2010 | White Mountain F69206X 6 Quart Ice Cream...
    The motor arm seems extremely loud. Machine is
    Run the machine in another room.
    It is due to Cuisinart's cheapo motor.
    Also try 1/2 to 2/3 fill batches.
    Put a book and a medium food can on top of motor arm to keep it from lifting while mixing.
    Jan 25, 2010 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
    Ice Cream Makers Logo
    232 people viewed this question
    Top Taylor Ice Cream Makers Experts
    Dennis Boxerman
    J.D. Browning
    J.D. Browning
    Andrew Taylor
    Andrew Taylor
    Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
