Question about Craftsman Garden
Just changed oil on the 4200 watt Craftsman generator, motor starts and runs 2-3 minutes then automatically shuts off for no reason. Any ideas on how I can solve this problem?
Try letting it run without anything hooked up to it. If that dossent work call crafstman and they will help you. Also u can bring it to a macanic,lawn mower shop. etc
Posted on Nov 10, 2012
  • 252 Answers
Make sure you put the correct type of oil in the crankcase for this machine
if you use the wrong type of oil ,oil level sensor float wont work and causes a shut down to protect the generator engine from damage
try draining oil and refilling with 20w/50 oil
cheers pauly46
Posted on Apr 03, 2011
My craftsman 5700 generator has gas inthe oil...why?
your float is stuck and wont shut of the needle and seat so it floods make sure you shut fuel of when not running and check your needle and seat and see if it shuts of the fuel from the tank
Oct 29, 2012 | Craftsman 5600 watt Generator
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
Potential Motor damage
Submersable pumps pull a lot of current on start up. Up to 7 times running momentarily. This is especially true of three wire pumps. ( Ground and 2 , 110V) 4 wire pumps have a capacitor start provision ( the extra wire) and a control box that greatly reduces the starting load by shifing the phase on startup.
4200 watts should handle it how ever if you have no line losses. Excess Line losses will do exactly what has happened to you. Overheated the connections and burned up the pump.
First check what gauge wire you have going from the generator to the pump and the length of the run. Check a wire gauge calculator such as http://www.denningelectronics.com/wiregauge.htm
use at least 4 times the running load for your wats and if it is a deep well pump, more than 50 feet of head from water to spickot) then use 7 times wattage. Use 5% line loss allowable,. This will probably uncover your problem as under size wire.
The other possibility is that the breaker was going bad over time and caused the voltage drop0 that destroyed the pump.
Last item you can do, check the voltage at the generator when the pump starts, it shold not drop more than 10% on start up.
Good luck
Mar 17, 2009 | Craftsman Air Tools & Compressors
Garden Logo
339 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
