Question about GE WCVH6260FWW
Washer wont fill - GE WCVH6260FWW
  • GE Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 03, 2011
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont initially fill. all other operations
Check the screen on the inlet hose from water fill. If not, it is the timer that you set (it's not functional)
Jul 08, 2009 | Kenmore Washing Machines
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Washer fills up but wont spin
roof, if it fills and just sits there it could be the pressure switch, grab the end caps on each side of the consol and pull them off. Remove the two screws under them and flip the consol up. On the left side you will see the pressure switch with a rubber tube going to it. Get yourself a piece of tubing about the same size in diameter. After the washer fills, remove the tube from the pressure switch and blow into with the spare tubing. If the washer starts agitating, the pressure switch is the problem. Catriver.
Sep 29, 2007 | Kenmore 13202 Top Load Washer
GE WCVH6260FWW Logo
219 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
