Question about Dishwashers
My De Dietrich DVF720XA1 dish washer has D13 over heating light on and even trying all the suggestions on the web I can't budge it.
  • paa_van_lint Apr 03, 2011
    Rickead1
    I have checked the No and it is correct. There is also a service No DVF720XA1/A plus a Type No of 1216421121100. The dishwasher is about 2 years old.
    Regards
    Peter
  • 1,998 Answers
Please recheck that model number that number doesnt come up at the de dietrich site when trying to look your unit up Thanks Rick
Posted on Apr 03, 2011
  • Rick Ead
    Rick Ead Apr 03, 2011
    ok first thing for some reason that model number keeps putting me to a de dietrich oven but you have it posted as a dishwasher so if you are having an over heat light on your dishwasher you would check either the element or the heat chamber due to the de dietirch site not recognizeing your model I am unable to see your unit but if your unit is a dishwasher is where you would start your tests these are the parts that heat the water in the unit and if there was a fault these are the areas i would start my testing most likely you have a heat chamber seeing as most of the overseas units do use a heat chamber so you would assure that the unit is getting power you would also check any fuses some units have a built into the door thermal cutoff switch that when it goes bad also gives you this error on some other types of brands if the thermal cutoff is working properly and you conducted a continuity test on the cutoff then you would remove the heat chamber and conduct a continuity test on the chamber as well message me back with your finds or if you have the manual to your unit message me back and il give you my email so that you can send me a copy I await your reply Thanks Rick
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
I have just purchased a de dietrich washing machine and I cant figure out how to set the anti crease option working.
try to read this :
http://www.de-dietrich.se/Files/Billeder/De%20Dietrich%20fotos%202012/DD%20brugervejl/Sverige/div/DLZ693W-UK-GL.pdf
Jan 24, 2015 | De Dietrich Washing Machines
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
My de dietrich oven is not heating. the light and fan are ok
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 28, 2011 | De Dietrich Ovens
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
My De Dietrich is not filling with water - pipe is on and water available. I've been away for a month - just got back and tried putting on the dish washer but it seems that the water isnt getting through...
Yes, lots of ideas. You need to disconnect the water line where it attaches to the dishwasher valve and see if water is flowing. If it flows, then you either have a clogged inlet valve (there is a screen inside the valve that catches debri from the water line) that could of happen from a disturbance of the water service orthe valve is old and lost its ability to open upon signalling, or the timer is not sending the signal to open the valve, or the water level (float) switch is stuck and not allowing the signal to get to the valve.
Nov 28, 2009 | De Dietrich 18 in. VW7451 Built-in...
Washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
390 people viewed this question
Top Dishwashers Experts
Owen Barnes
