I have an Epson Stylus T24, I have replaced one cartridge with a compatible cartridge, and then the printer didn't recognize neither the new cartridge that I replaced nor the other 3!! I don't know what to do, now I can't use the printer.... Tahnks
    Sergeant:
  • 279 Answers
Take off all the3 ink tanks, find the chip connector, clean them with dry tissue paper then put them back
Posted on Apr 03, 2011
No longer recognizes the ink
Are you using compatible ink cartridges? When a compatible cartridge is empty in an Epson printer the printer reports "Cartridge not recognised". This is Epson's way of scaring you into using Epson branded cartridges. Just change the cartridge and it should be OK.
If it's not that issue then maybe the chip on the cartridge is faulty. Again, just change the cartridge.
Aug 07, 2013 | Epson Stylus CX5000 InkJet Photo Printer
Printer does not recognize the new cartridge, but doe show the old cartridge as being empty so it does recognize that one.
Are you using original Epson Cartridges? if not, that might be your problem. The cartridges have chips in them and the printer might not recognise some imitations. Also, if you have recently done a firmware upgrade on your epson, you will probably never be able to use compatibles again.
Aug 25, 2011 | Epson Stylus Pro 4000 InkJet Printer
How do i get compatible cartridges T069 to be recognized by the nx415 Epson printer?
i found out a site that offers cheeper compatible ink cartridges... try to check out this site: http://www.swiftink.com/Epson-Stylus-NX415-Ink-Cartridges-s/3544.htm. they do offer warranty should these inks dont work.. and they are safer to use because they do have quality control even thought its remanuctured.
Jul 14, 2011 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Your explanation does not seem feasible.. Without any problem I have been using Epson Compatible cartridges for about one year, in the same printer (Epson Stylus SX215). Why should exactly the same type...
Maybe there are corrupted file in the installed software from your driver so your PC can't recognize the cartridge. Try to re-install printer driver with the cartridge placed inside the printer.
Hope this help.
Feb 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Nov 17, 2009 | Epson Office Equipment & Supplies
I have an Epson Stylus 4400. when I replaced the ink cartridge with a new Tesco cartridge it still registers empty.
Compatibility issues. The epson cartridge has an intellidge chip so the printer's sensor can read the cartridge properly.
Try to take the cartridge out then put it back in to the printer. Let it charge like it normally does.
Use an epson cartridge. Log on to epson.com to get the compatible cartridge for your printer.
Apr 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus dx 7450 printer
You have a wide format printer but it has the same basic principle as the desktops. You can buy remanufactured cartridges which were reset for you. Or you can refill them. If you refill them, you need a resetter because Epson cartridges have a chip on them which needs to be reset. Because when they are empty, the printer will recognize it as empty and will not function till you put in a new cartridge. If you bought a remanufactured cartridge, and your printer won't recognize it, you need to go back to who sold you the cartridge and either have them reset it or give you a replacement.
Jun 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
