Question about Home
Everytime you flush the toilet, water supposed to fill up the cistern and stop. In this case water keeps on ruuning from the cistern to the bowl continuously.
One of 2 problems may be present, first may be the floating ball, it may not be getting back to the correct position and there fore cut the water supply off, as it should, you can check to see if this is the problem by lifting the arm up a bit and see if the water stops flowing, if it does then to fix this i bent the alloy arm that was holding the floater a little more in the down ward position, if not the problem the the rubber seal at the bottom is most likely not sealing properly, may just need a wipe around, a bit of a tight squeeze, turn the water off first, have a go
Posted on Apr 03, 2011
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Water running into the bowl after flush and refil
IT SEEMS TO ME THAT THE BALL-**** (FLOAT SWITCH) IN THE CISTERN IS SET TOO HIGH UP. THERE ARE MANY DIFFERENT MODELS BUT ALL SHOULD BE EASILY ADJUSTED. HAVE A LOOK INSIDE THE CISTERN AND ADJUST THE FLOAT SO THAT THE WATER STOPS AT A LOWER LEVEL. IF THE WATER IS CONTINUOSLY FLOWING INTO THE CISTERN WHEN FULL YOU MIGHT NEED A NEW INLET WASHER
Feb 08, 2012 | Saniflo & Saniplus& Macerator Pump
After automatic flush, water continuously runs into bowl. The water is coming from the upper bowl above the wand area.
i would think the syphon is not closing after the flush, so as the cistern fills it just runs straight into the pan. you'll need to replace the syphon...
Jul 07, 2011 | TOTO MS990CGR Neorest 600 One Piece...
Hi i have a closed cistern on my toilet and the flush wasnt working! Eventually got lid off after much turmoil and flush works without lid but when lid is fastened on - it flushes but water keeps syphoning...
If water is constantly running into the cistern you will need to change the rubber washer in the shut-off valve. Washer kits are available from most DIY stores. Turn the water off at the isolating stop-****. Unscrew the end of the inlet valve (watch out that any springs etc. don't ping out) change teh washer and reassemble in reverse order.
Feb 17, 2011 | Plumbing
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
The toilet was installed under the stairs a year ago and has hardly been used - the bowl keeps filling after flushing and overflows, I cant shut it off. It flooded the down stairs twice now - all over...
Take the lid off the cistern tank and have a look. There is a ( usually ) round float ball in there. This is what is causing it. When the cistern fills up the ball is supposed to float up and the arm it attaches to shuts off the water, usually at the opposite end to the float.
Turn the tap on the pipe to the cistern so it is nearly off and move the arm up and down by hand. See what it is getting stuck on or what is happening.
If it is not a simple sticking problem, you may need to undo the top of the cistern valve itself ( opposite end to the ball. )
Turn the water off completely to the cistern to do this or you will get squirted. :)
They are fiddly little valves and all a bit different but if you take your time and make sure you have a good light you will be able to work out what has been happening.
Hope this is some help.
Oct 17, 2009 | Saniflo SaniBest-Round SaniBest Macerator...
Home Logo
335 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
