Question about HP Pavilion F1703 17" LCD Monitor
There's a green line going down vertically on the monitor screen all the time
    President:
  • 1,623 Answers
A resitor line has failed and you cannot fix it, once they fail thats it ,its there for good. Its same as dead pixels on a monitor, except this is a whole line of pixels, if you hit the area above the line hard it will probably go away but will come back sometime, learn to live with it or buy a new monitor.
Posted on Apr 03, 2011
Why is my screen green?
you may change the connection cable
Aug 18, 2015 | ASUS VW246H 24 Widescreen LCD Monitor,...
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
There are two vertical lines on my monitor one is red and other is green
You may have several issues, lets try to narrow down whats wrong. When you see the lines hit the print screen button. Then go into Paint and select paste, this should make an image of whatever was on the screen when you hit print screen. Are the lines still there in the same spot? If so check the cables between your monitor and the PC. If not it is your monitor, check around for magnetic devices near the monitor if you can not find any the monitor may be bad.
Mar 12, 2011 | Computers & Internet
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Vertical lines on screen
3 problems:
1. your monitor but i doubt it
2. vga component in your computer
3. atx component in your computer.
try go to a friend and make some changes. don't buy anything first. just test them to see what's bad.
Nov 01, 2009 | BenQ FP71G+ 17" LCD Monitor
Green vertical line on LCD screen
Is this on a monitor or on a laptop LCD display?
Most of the time it is due to a hardware issue like a video card or the screen itself.
When does the line appear?
A. Is it there even with the monitor or laptop turned off?
B. Is it there during the OS logo / boot screen or does it appear after the OS loads?
C. If it is a monitor, with your system turned off go into the menu of the monitor by using the buttons on the front. Is the line there?
What you can do to try and fix it is.
1. Make sure you have all the latest drivers for your video card.
2. Change the resolution of the screen.
3. Change the frequency of the monitor.
If these do not fix your issue you may want to look at getting or borrowing a video card and replacing it if this system is a desktop. If this system is a laptop and the above does not fix the issue your best bet would be to put up with it or buy a new laptop to be honest.
Jun 19, 2009 | Acer 22" X223w LCD Monitor
Green line vertical on screen keeps appearing
in the monitor menu button you will be having a option called "degauss" give that when it appears ...
if you still persist the same problem then there may be some problem in the CRT tube ....
just take your monitor to the technician ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Green line
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you.
Mar 10, 2008 | Acer AL2216WBD LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
269 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
