Question about Legacy Audio American Legacy II LA690 Car Audio Amplifier
I had the la 690 in my car then i took it out and put it back in 1 month later now there is no sound coming out of it and the green light is on??? all the fuses in the system are good
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
U might just have a bad ballast. It generates the high voltage to fire up your bulb.
Jul 28, 2017 | Sony Televison & Video
I have a 1998 Mazda Millenia.I've had the car about 2 months and everytime i crank up in the morning or after being parked about 9-10 hours white looking smoke comes out the tailpipe.My check engine light...
The white smoke in the morning is condensation heat attracts moisture, Now for a 1998 you may have to add Mazda transmission fluid in it. That siren noise is the underdrive of the transmission they have alot of issue Make sure underneath the transmission area there is no red fluid other than that you will be needing a transmission ,
Apr 21, 2011 | 1998 Mazda 626
Check engine light and knocked off rockers
Running rough and misfiring is usually a one or more bad spark plug wires. Don't go back to that dealer. Replace the wires or have your mechanic do it for you. If you replace them, take one off at a time and install the new one. If you put the wires back on in the wrong order, it will misfire.
May 25, 2010 | 2003 Jeep Liberty
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
My 98 ford expedition check engine light came on and it skips at 65 or higher
you have a bad sensor check all sensors starting with air. berrydalewolf
Oct 26, 2009 | 1998 Ford Expedition
The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
May 23, 2009 | Samsung Digimax L730 Digital Camera
Want turn on getting number 1 and 3 flashing
Your Power Supply has gone bad mate... known problem. You need to swap out the old power supply with a new one or maybe a working one (if you have another system)... the procedure is fairly clearly documented on the Dell Site n no Tags needed for that... :-)
Feb 11, 2009 | Dell Precision Workstation 690 -1KW Dual...
Two-fold problem: (1) Check engine light would come on when I was low on fuel. After refueling, it would go away. Eventually it came on and stayed on so I took it to the shop. They said it needed an...
It sounds like the emissions system VAPOR CANISTER VACUUM has a vacuum leak from the canister to the motor & its not reburning all of the fuel. An emissions test is in order with a computer scan (2nd opinion) (someone took a bad guess)
Mar 17, 2017 | Chrysler 300M Cars & Trucks
Legacy Audio American Legacy II LA690 Car Audio Amplifier Logo
78 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
SXTechHead
SXTechHead
Professor_V
Professor_V
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
